Singer Inspiration 4206 Logo
Posted on Jun 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot get the tension right and the thread keeps braking
Anonymous
Level 3:
  • Master 1,238 Answers
  • Posted on Jun 06, 2011
Anonymous
Master
Level 3:
Answers
1238
Questions
0
Helped
329904
Points
3603
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
My kenmore model385.16221300 the thread keeps braking and the underside has big loops of thread
What you have is bird nesting or thread nesting and could be a result of several things. Usually, it is because the machine is mis-threaded, the thread is not seated in the tension disk, and/or the upper tension is too loose.
Remove the upper thread. ALWAYS raise the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low number. Retest your machine.
You may need to tweak the upper tension to get it where it should be as all machines differ. The tension is correct when the upper and bobbin threads meet in the middle of the fabric.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Upper thread keeps braking
Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Install a brand new needle.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Sewing Machine Thread Keeps Breaking
Why is my thread breaking
Sewing Machine Problem 1 Thread Breakage
1helpful
2answers
I can't get the tension right. The stitches on the top side are too loose and the thread just pulls out.
loosen the needle thread tension of a bit
sew on a scrap bit of material until you get the tensions right
correct tension is when the bottom thread and the top thread meet at the join of the two pieces being sewn
you will only need to sew 1" to see how it is going
My top thread keeps snapping on my consew 118. There are loops on the underside when I stitch with it and the thread keeps snapping at the needle. It is threaded right but it keeps happening literally...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Thread looping on the bottom of your fabric can be caused by little or no top tension or too much bobbin tension. Another cause is thread or lint caught in the top tension.
Make sure the thread is between the tension discs and that no thread or lint is caught
2helpful
Jucan`t thread serger 920d thread keeps braking
here are some suggestions
Is machine threaded correctly, check each thread guide, all tension dics
Are needles inserted correctly
Are the needles bent or damaged
Is tension adjusted to tightly
Is tension adjusted to accommodate thickness of thread being used
Are you using good quality thread
Is thread feeding off cone/spool freely
Is the needle size correct for the type of fabric being used
Are the needles being used the correct ones for the machine
1helpful
Upper thread keeps braking on brother galaxie 2100
With the pressure foot in the up position, pull on the thread right before the eye of the needle to ensure its not getting snagged up on anything.
Make sure your top tension dial is in the middle setting (usually 4 or 5)
What type of thread are you using? Cheaper thread such as Coats and Clark and old thread is very weak. Check out your local independent sewing dealer and have them recommend thread to you based upon the fabric your using.
hope that helps,
Chris
I can't seem to get my tension right. It keeps skipping and putting loops on the under side of fabric and the thread keeps unraveling and breaking . Tacsew T111-155
Check the needle to be sure it is the correct size for the type of fabric you are sewing and does not have a burr on the tip.
Raise the presser foot when threading the machine and this will open the tension control so the thread can properly seat into the control and form a proper stitch.
When the machine is threaded with the presser foot down, the tension control closes and the thread cannot enter as it should. In this case, the bobbin thread is the only thread with tension.
2answers
I cant set the tension on my PFAFF 7570 the thread keeps
First make sure your needle is in correctly. Then make sure you are threading the machine correctly especially make sure you thread the take-up lever. Make sure your tension dial is at a 4 to 5. if this does not work, let me know
Thred keeps braking
It might be tension to tight, threaded wrong or the bobin isn't thread the right way.
1helpful
O cannot quite get my tension right.
Adjust the dial below upper tension unit (where you thread the top thread) to increase/decrease tension as needed. You might also want to check for loose threads or fluff in the tension area keeping the discs from closing correctly. Good luck.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
