Hallo. I got a problem with radio DEH-P9300R. Actually i bought a car with this radio already installed. The problem is when i turn it on and choose cd compact playar and i cant eject a cd whth is already in. How do I eject it? Pressing open(eject) button doesnt work. Please help me with this
Mosfet 50wx4 indicates a feature of the Pioneer car radio. It isn't a model number. One Pioneer car radio/CD player with this feature is the DEH-1500. On this model, you need to turn off the unit to set the clock. Press and hold the Source button (to the left of the preset tuning buttons) until the device turns off. Press Audio (upper right corner) repeatedly until the clock appears in the display. Use the arrow keys (Skip/Back or Left/Right) on the right hand side of the radio to select a segment of the time to adjust. Use the Up/Down arrows to set the current time. Repeat choosing the time segment and adjusting the time until both the hour and minutes are correct. Press Band or press and hold the Audio button to exit the clock setting mode.
Make sure the yellow wire is going to a source that still has 12v when the key is turned off. The yellow wire controls the memory and needs to be connected to a constant power source.
You should be able to see two (2) small grooves on the face of your VW radio, one on each side of the radio. You will need to insert a small flat tool into both slots simultaneously to release the radio from it's cradle. A small flat head screwdriver might actually work.
Depending upon the radio being installed, it might actually fit into the existing cradle, or you may have to partially disassemble the dash in order to switch cradles.
I have the same radio, the Pioneer DEH-10MP, bought at BestBuy. Anyway, the instruction manual is completely wrong, as you already know. The solution that worked for me is:
1) turn off the radio. 2) Push and hold the power button down (the dial). DON'T release the button. 3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min). 4) use the up/dwn, right/left buttons to set the clock. 5) turn off the unit by pushing the power button (again, the dial).
did you check to make sure your vehicle didnt come with a factory amp, if it has one is it turning on? or did you remember to disconnect the negative battery cable while installing your radio, i know thats a dumb question, once i was installing a pioneer a barely crossed a couple wires and fried the radio, the radio itself worked fine and all the features etc, but it never did play sound again. i always disconnect the power now!!
To set the clock on the pioneer DEH-P2900MP Detachable face radio/CD/MP3 Player, follow the following steps in order.
Press the large round knob and hold for 5+ seconds to tuen the radio "off".
Once the radio is off press and hold down the large round knob 5+ seconds to enter clock set mode. (Note: You must hold the knob down otherwise you will just turn the radio back on.)
Now choose the < or > button next to the large knob to toggle between hours and minutes. Rotate the knob to adjust the digits.
When complete press the radio/sat button @ the top right of the stereo face.
When finished, quickly press and release the large knob again to turn the radio back on.
turn radio off, and press the "audio" botton until clock is displayed. then click it again shortly till you see "FM 100" on the display, press > (side arrow, now it should switch to "FM 50". long press on the "audio" to save and exit.
afterwards it should work fine.
