Question about Pioneer Car Audio & Video
How do i install a pioneer deh-1550 car radio
Posted by James Murphy on
Andrew Taylor
    Top Expert:
  • Pioneer Master
  • 34,193 Answers
The installation manual is here
Pioneer DEH 1550 Installation Manual
PIONEER DEH-1550 INSTALLATION MANUAL Pdf Download.
https://www.manualslib.com > ... > Car Stereo System > DEH-1550 XU
View and Download Pioneer DEH-1550 installation manual online. DEH-1550; DEH-1550B. DEH-1550 Car Stereo System pdf manual download. Also for: Deh-1550b, Deh-3450, Deh-2450f.
[PDF]DEH-1550UB DEH-1550UBG - Pioneer
www.pioneer-latin.com/.../operating%20manual%20(deh-1550ub)-eng-esp-por.pdf ???? ???????? CD ?? ????? RDS. ?????? ?????? CD RDS. Espa?ol. DEH-1550UB. DEH-1550UBG. Portugues (B). Owner's Manual. Manual de instrucciones i ... PIONEER Service Station. Press to recall preset stations. Press to select the next/pre- vious folder. AUX input jack. (3.5 mm stereo jack). 6 Disc loading slot 3. O USB ...
How To - Understanding Pioneer Wire Harness Color Codes for DEH ...
? 6:05
https://www.youtube.com/watch?v=kR2MO2kwFug Nov 14, 2016 - Uploaded by pioneerelectronics
Learn about the Wire Harness Color Codes for Pioneer in dash receivers that do not have video screens. DEH ...
How to restore and reset your Pioneer DEH radio - YouTube
? 1:20
https://www.youtube.com/watch?v=_QyuVanWfLA Jul 26, 2016 - Uploaded by Five Star Car Stereo
in this video we show you how to restore your radio into factory default settings. ... to restore and reset your ...
Posted on Mar 24, 2018
5 Related Answers
Anonymous
SOURCE: pioneer deh-p2000
turn off radio with ign. on-- depress source button for 3 sec. then function button for 3 seconds until clock appears--use arrow keys to set hours and minutes.
Posted on Oct 12, 2007
tedgoodier
  • 36 Answers
SOURCE: Pioneer Car Radio #DEH P4901B
This link will take you to the Pioneer page with the link for both the Owner's Manual and the Installation manual of your specific model.
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/CD-Players/DEH-P490IB?tab=D
Clicking on the link will ask you to register (no cost involved) and then you can download or view the manual.
Hope this helps
Posted on Dec 18, 2007
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Need wiring diagram for pioneer
pioneer deh-1550
yellow-->purple (Rear Right)
gray black-->purple black
yellow--> green (rear Left)
gray black-->green black
Black--> black (ground)
Green--> red (ignition)
blue--> yellow (power)
Posted on Dec 21, 2008
Anonymous
  • 64 Answers
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Posted on Feb 18, 2009
Anonymous
  • 89 Answers
SOURCE: pioneer deh-2800 50x4 how can
1) Press "source" and hold it until the unit turns off.
2) Press "audio" hold until clock appears in the display.
3) Use teh < and > to select the hour and minutes.
4) use ^ and v keys to change time.
Posted on Apr 17, 2009
Trying to install a new pioneer radio to a 1999 jeep
try walmart they have the wiring harness that you need to install your radio for about 6 dollars
Aug 10, 2009 | Pioneer DEH-1100 CD Player
Need to install a pioneer cd player to a DEH-1550. Can I please see a diagram?
the easiest way if u still have ur harnest in tacked in ur car go to ur radio store and get a kit and a wire harness kit and match the colors. if u dont first get a volt tester with a light first find ur poewer and constant. constant will turn ur light on auto matic. the power will turn on when u turn ur igintion. once u find them put them aside now the rest of the wires. get a AA baterry and try one wire at a time once u hear a pop thats the first speaker tape it together. and do the rest to the rest of the wires
Jul 03, 2009 | Pioneer TS-A6962R Car Speaker
Can Pioneer DEH-P7000BT be installed in 1996 Jeep Cherokee?
I can tell you it will be no diffrent installingthis radio then any other radio in any car as long as you got ground +common -common ground and 12V+ Standing power 12V+ ingntion swtich power ons you will be great!! Just make sure you download a diagram of you wire harness on the internet. Print it out and take it to your jeep and careully follow the instructions on there if you need any help give me a shout :)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Pioneer DEH-P7000BT Car CD/ MP3 Player
I'm looking for the wiring connection for a Pioneer DEH-1350 Car CD Player/Radio and operating instruction Thanks, Karl.
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-1300.Support there is the link where you can download the manual and the install paperwork
May 02, 2009 | Pioneer DEH-1300 CD Player
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
DE-ACTIVATION CODE FOR A PIONEER RADIO
there is no code for a pioneer radio expecially for the deh p720. what is wrong or what does it do
Jan 25, 2009 | Pioneer DEH-P7200 CD Player
Stuck installing my Pioneer DEH-1000E
yes try that. I had a Isuzu Bighorn and put a new Sony CD player in, but i used the old casing to fit the new one. so you could try using the old casing, or buy a new one.
Jan 10, 2009 | Pioneer DEH-1000 CD Changer
Need wiring diagram for pioneer DEH 1550
pioneer deh-1550
Dec 17, 2008 | Car Audio & Video
DEH-P3500
pioneer keys. Long thin with a tiny barb at the end. You need keys, and remove the radio trim piece. Take to local shop and they can do it in 2 seconds.
Feb 17, 2008 | Pioneer DEH-P3500 CD Player
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Car Audio & Video Logo
431 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
