I bought a Mp3 player from radio shack and it didnt come with a charger. And I would like to purchase one.If you could direct me to nearest store that sells it in Gallup,NM. Or if can purchase one from your company.
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
when you plug a charger to your mp3 it plays, because you power from a charger, part of current goes to aset and make it play and also charge your battery.
when you unplug it from charger than battery does not manage to provide power to set.
get a meter and set at amps dc. and check your battery current out side.
i suspect that your battery is not holding charge.
On your computer, go to Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> Device Manager --> and uninstall the item marked MTP device. It will be a bit tricky b/c the Sansa will cut in and out during this process.
Uninstall all Sansa software, and reinstall the clean version from Sandisk's website.
I used to work in a IC design department where we disigned IC's for creative. It is a problemn of the lition ion charging circuit. When voltage drops under 0.9 volt (if I remember clearly) It will not detect
the battery anymore and wil not charge..
So, solution:
1 try to charge the battery manually for a short time, disassemble the vision and connect the battery to up to 3.7 volts. For a while, later your device can charge it further, by itself
I had the same freeze problem and after doing everything I could think of I read the downloaded user manual and found the answer was to hold down the menu button for 15 seconds. It acts as a power off button and cancels out the last operation thereby unfreezing the offending action.
