SOURCE: Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
SOURCE: Brother 5250 DN Paper Jams
You problem is actually in the pick-up roller and separation pad areas. the paper is delaying and not making it through to the next check point in the machine fast enough.
1st
Take it by your closest Brother Service Outlet. They're in the phonebook under "Computer Service & Repair". It's a cheap fix but requires parts.
2nd
Use good paper. Paying a little more for paper will save you a lot over time in repairs and premature toner and drum failures. Brother printers are really finicky about paper quality. Recommend "HP Office" brand paper as a minimum. It's a known good paper for general everyday printing and won't break the bank.
SOURCE: Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
SOURCE: Brother 2140 toner light on, won't even try to print.
To get every bit of toner powder out of the cartridge, first remove the toner unit from the drum assembly. Second, find the little circular window on the right-side of the toner cartridge. Third, place a piece of black electrical tape over the clear window, cannot be clear tape. Fourth, re-install the toner cartridge into the drum assembly. Last, put the complete unit back into your printer. This worked for me.
SOURCE: Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
