SOURCE: Leaky Tassemo coffee maker
i think it's supposed to do that. the cup at the base is supposed to be catching all the water that the tassimo is 'leaking'. it should be dumped after every cup of tea/coffee. if you have taller cups, and do not use the cup base that comes with the machine in order to fit the taller cups under where the tea/coffee comes out, then you are right. it seems like it's 'leaking' because it is. there should be enough room in the base for one cup, but then it can also be removed so as to dump the excess water out after the cup is made. hope this helps!
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
SOURCE: directions on how to use my Black and Decker Espresso Mio coffee maker
The .pdf of directions/instructions is located here:
http://useandcaremanuals.com/pdf/EE100-EE20013.pdf
SOURCE: Need to find cleaning tablets
Espresso machine cleaning tablets: http://www.kaldi.com/cafe_supplies.htm
it sems the pressure pump is off... If I get it as a part, how do I change it...?
