Hi the details are below.
Hope it helps
I have added a link for the manual at the very bottom, Good luck with it.....
Time
Adjusts the systems clock. The time difference
(+, -) between the time originally set in your navigation system is set here.
You can also select summer time On/Off.
> Time settings, (See page 131)
Summer Time
Choose whether or not to take summer time into
account.
On:
Summer time is taken into account.
Off*
Summer time is not taken into account......
When the period of summer time comes, or
when the summer time ends, your navigation
system does not automatically change the
summer time setting.
> Change the summer time setting, (see Page 131)
To set the time difference, touch "+" or
The time difference between the time originally set in the navigation system (Pacific
Standard Time) and the current location of
your vehicle is shown. If necessary, adjust the
time difference. Touching "+" or "-" changes
the time difference display in one-hour increments. The time difference can be set from
+3 to -3 hours.
If necessary, set to summer time.
Daylight Saving Time (DST) is off by default.
Touch "Off" to change the time if you are in
the daylight saving period. This turns the display below summer time "On".
9 To complete the setting, touch "Back".
The map of your surroundings appears.
This completes the setup of your navigation system. Chapter 1 explains the basic operation of
> To change the time later, (see page 75)
The link to manual here:- http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/417273154AVICD3OperationManual0221.pdf
Directions for Desk Clock - Without the
C?/F? button
To
change the Temperature:
Press
the "S" button once (this will change from Fahrenheit to Celsius)
To
change the Time and Date:
Press
the "M" button once to change time to or from military time
Press
the "S" button once to change the hour
Press
the "S" button again to change the minute
Press
the "S" button again to change the year
Changing the year will also change the day of the week
Press
the "S" again to change the month
Press
the "S" again to change the date
To
set the Alarm:
Press
the button with an alarm clock on it
Press
the "S" button once
A flashing 12:00 should appear
Press
the arrows to set the hour
Press
the "S" button again to set the minutes
Press
the "S" button again to change the "ring" of the alarm
There will ne a number below the time the alarm is set for
Use the arrows to advance through the options
To
turn the alarm functions completely off:
Press
the button with the alarm clock on it
Press
the "S" button five times
When three dashes appear where the time would be, it is off.
Press
the "M" button three times to get back to the main clock function
To
clear the secondary clock:
You
can set two different times on the clock, so if you travel frequently you can
have a home time with alarm and a travel time with alarm saved and ready to
go. There is a primary time, the one you normally see on the clock with
an alarm clock function after it. There is also a secondary time with an
alarm function after it.
Clearing
the secondary clock will make it easier to know when you get back to the
primary clock function.
Press
Press
the "S" button seven times
Press
the "M" button two more times
And
you are Done!
