Brookstone Self-Setting Atomic LCD Clock Logo
Maria Morand Posted on Jan 07, 2014
How do I set the time zone? It run out of battery so when I changed it, the time zone is pacific and I need to change it to mountain time.
xnewyorka
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 07, 2014
xnewyorka
Contributor
Level 1:
Answers
Questions
Helped
1615
Points
5
To change the time zone, open the control compartment cover on the bottom of the clock. Locate the "Time Zone" switch and set it to the appropriate time zone for your area. Six time zones are programmed into your clock, "A" for Atlantic, "E" for Eastern, "C" for Central, "M" for Mountain, "P" for Pacific and "H" for Hawaiian. Once you've chosen the correct time zone for your Brookstone digital desk clock, you must select whether you want the clock to operate using the 12-hour or 24-hour format. The clock is set to the 12-hour format by default. If you'd like to change the setting to the 24-hour format, locate the "Time Format" switch on the bottom of the clock and flip it to "24-hour".
You can also decide whether to turn your clock's automatic Daylight Savings Time feature on or off. If you turn the feature on, your clock will automatically move forward by one hour at 2:00 a.m. on the first Sunday in March and fall back by one hour at 2:00 a.m. on the first Sunday in November. To choose your preference, locate the "DST" switch on the bottom of the clock and flip it to "AutoHow do I set the time zone?  It run out of battery - icon1.png" or "Off".
Read more: http://www.ehow.com/way_5585650_brookstone-digital-desk-clock-instructions.html#ixzz2phA7kQ1b
We are on Mountain time and Alexa is on Pacific time. How do I fix this.
Change the time zone.
How to change the time on your Amazon Echo speaker, Show or Spot
  1. Tap More in the bottom bar.
  2. Tap Settings.
  3. Choose Device Settings.
  4. Choose your Echo device.
  5. Under General, tap Time Zone.
  6. Choose your Country and Time Zone.
How to change the time on your Amazon Echo speaker, Show ...
1helpful
How do I change the time zone for model 31981B?
How To Set Your Time Zone
Time Zones around the world are identified by how many hours they are off-set from Greenwich Mean Time. US time zones are 5 to 9 hours behind Greenwich Mean Time and are identified as:
Eastern -5 Central -6 Mountain -7 Pacific -8 Alaska -9
Your SkyScan model 31981 is pre-set to Pacific Time. To set your clock to your time press and hold the mode button for 2 seconds. The off-set hours will appear and blink in the clock window. Press the up or down button to designate your time zone. Press the alarm button to exit time zone setting mode.
http://skyscanatomicclocks.com/manuals/31981.pdf
2answers
How do I change the time zone?
Radio controlled atomic clock self sets, and self adjusts automatically. This clock is very easy to use!,Daylights Saving Time on/off option; 4 Time Zones - Pacific, Mountain, Central, or Eastern,Folds into smaller size for easy storage and travel; travel pouch included,Automatically sets day, date and time; 2 separate alarms - great for weekends,Sturdy, contemporary construction. Stand folds for easy storage. 2x AAA batteries included; as shipped to U.S. Government and institutions
1helpful
2answers
Need a user manual for skyscan model 31420e atom travel clock
Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
I have an Eddie Bauer Wireless Thermo Clock model 0465.\r\nWe replaced the battery and now it is on the wrong time zone. How do I change it>?
Re: Eddie Bauer Wireless Thermo Clock - Model 0465
TIME ZONE SETTING
The default time zone is PACIFIC (P). lf your location is not in the Pacific zone, set the time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln alarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern.
4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit automatically 30 seconds later without pressing any key.
This sequence fixes my thermo clock. Follow step-by-step ......
Sent via Mobile GMail Services
06.20.2021 KJ Bleus Parsons
17helpful
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
67helpful
3answers
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 • Watches
12helpful
Can not change the Brookstone Projector clock from Pacific time. We live in eastern time zone. where do I get a manual
Choosing a time zone. To select Pacific, Eastern, Mountain or Central time zone, press ZONE button inside battery compartment of clock unit.
9helpful
Can't set time zone
Try pressing and holding the -CF for three seconds then press it again. The P (Pacific Time) appears, press it again and the M (Mountain time) appears, etc.
Nov 21, 2007 • Watches
Top Brookstone Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
