20 Most Recent Ken Tech Large Digital Atomic Clock Questions & Answers
Check to verify the correct time zone and/or DST has been selected.
Ken Tech Large... | Answered on Jun 03, 2016
Look for a setting to change from 24 hour to 12 hour clock display in your clock menu settings.
Ken Tech Large... | Answered on Jan 03, 2015
This is a very common issue. Unplug the mini power jack the thing with the cord. Look inside the chargers hole on the jam box and then take a knife to gently bend the tab back towards the middle or even lower. Be careful when you are re plugging into the power into the socket. The socket tab and the mini plug must meet .
Audio Players &... | Answered 13 hours ago
The AUX connection is what the Line In connection used to be called and generally has a medium impedance and a sensitivity of upwards of 800 mv, often 1 to 1.5 volts, being the typical output of a tuner or tape deck.
Details of this is usually found in the user manual - good matching is repaid in better quality sound and reduced interference.
Audio Players &... | Answered Yesterday
Press the buttons of your mystery appliance in the correct order.
OR
You could Google
make model manual
Audio Players &... | Answered 2 days ago
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Audio Players &... | Answered on Jul 30, 2020
Press and hold the MFB buttons for about 5 seconds to turn them off. When both earbuds are paired with your cellphone, press and hold the MFB button on either left or right earbud, the other earbuds should turn off at then at the same time.
Audio Players &... | Answered on Jul 29, 2020
The speakers may be burned out.
Audio Players &... | Answered on Jul 27, 2020
The manual has the complete process how to set time.
Audio Players &... | Answered on Jul 22, 2020
A faulty volume potentiometer? Some internal cross-talk? Free wires induction because they are too close, inside? It sounds possible to me and a minor problem. Don't worry too much.
nothing exists on repairing one. Docking systems are a disposable item. Take it to an electronics engineer for diagnosis and repair.
www.manualslib.com > ... > Docking Speakers > inMotion IM310
return to the dealer, or call the Altec Lansing service line for assistance. IMPORTANT SAFETY INSTRUCTIONS 16. For products which incorporate batteries, ...
Altec iM310 inMotion Compact Audio System - YouTube
www.youtube.com > watch ? 2:52
Jun 14, 2010 - Uploaded by TigerDirect
Affordable, amazing sound for music lovers who listen with their eyes as well as their ears! This new addition to ...
Altec Lansing inMotion IM310 ' Manualzz
manualzz.com > doc > altec-lansing-inmotion-im310
User's guide Caution: To prevent the risk of electric shock, do not remove cover (or back). No user-serviceable parts inside. Refer servicing to qualified service ...
Audio Players &... | Answered on Jul 18, 2020
Usually clocks use the frequency of the AC supply to keep time, a synchronous motor was used in the old motorized clocks. If all the outlets eventually go back to one incoming supply, they all share the same mains frequency.
If it is a quartz reference type, then temperature may be a factor - extremes of temperature will cause deviation in the main oscillator. Otherwise, time appears to be passing at a different rate in that room!
old LED clocks did not have a crystal, they had a counter that counted the 60 cycles power, an intermittent connection will create extra pulses that will be counted. That will make it run fast.
it possible the outlet makes an intermittent connection (loose plug, maybe) so that the clock intermittently switches to battery backup on a lousy quartz crystal timebase that runs too fast during these periods? Remove the battery & see if the clock resets to 12:00 periodically.
Audio Players &... | Answered on Jul 16, 2020
Ken Tech Large Digital Atomic Clock Logo
8 questions posted
Popular Products
Top Ken Tech Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Ken Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Ken Tech Audio Players & Recorders
Most Popular Question
setting time
  • Audio Players & Recorders
