OA means that the sensor is not detecting any heat in the boiler. That means either the boiler is not heating or the sensor or sensor wire is detached from the boiler or the sensor has failed. The sensor is located behind the front display panel stuck in the front of the boiler and it has 2 thin wires in it with push on terminals.
The E08 preheating error code appears if the set oven temperature is not reached within 50 minutes. If this code appears, the reason might be due to overheated thermostats, a defective heater or a defective relay; in which case a repair will need to be arranged.
However, if food has been put into the oven during the preheating time that may cause the error code, since the presence of food cools the oven and so it doesn't reach the right temperature. The error message can be removed by turning the oven off and turning it on again.
To prevent this error code from happening again, the oven should not be used during the preheating period. The preheating period ends just after the sound signal and the icon in the display have turned off. When the oven gives the signal, it's close to the set temperature and your food can be put in.
You have four free technical supports via phone from Microsoft. Make sure that you write down the error code exactly, so you can give it to technical support person. you can start at this page https://support.microsoft.com/oas/default.aspx?gprid=11732&st=1
Error code "OA"....machine thinks it has a faulty Laser unit. You can try a reset ( Menu, *,M..press ENTER.) if it resets GREAT.
If not and the code comes back,most likely Laser unit is defective.
Expensive and time consuming repair.
