Question about Krups Coffee Makers & Espresso Machines
Error code OA on Krups EA8080 - Krups Coffee Makers & Espresso Machines
Posted by mulyadi dasril on
Ross Keen
  • Krups Master
  • 1,364 Answers
OA means that the sensor is not detecting any heat in the boiler. That means either the boiler is not heating or the sensor or sensor wire is detached from the boiler or the sensor has failed. The sensor is located behind the front display panel stuck in the front of the boiler and it has 2 thin wires in it with push on terminals.
Posted on Jul 18, 2018
Testimonial: "thanks your answer.."
  • 4 more comments
  • mulyadi dasril
    mulyadi dasril Jul 31, 2018
    solved Error 0A , I have just changed two fuses. After Run the self diagnostics and error code 09 has appeared, suggesting I need to contact the service agent. Please help.
  • Ross Keen Jul 31, 2018
    That is listed as pretty much the same fault as 0A so you still need to be looking at where I pointed you. If the fuses were blown then that indicates overheating so maybe there is a fault with that little panel glued to the front of the boiler. The panel is only available as part of the whole boiler assembly so it's looking like the sort of repair that's not worth doing.
  • mulyadi dasril
    the fuses were not blown.
    What should I do?
    If the wires are still attached to the panel on the boiler then very likely only a new boiler is going to fix it. I think it's probably going to end up too expensive to fix so only good for the bin.
  • mulyadi dasril
    i don't know price thermoblock , price Krups EA8080 machine in indonesia $842.99. are know price thermoblock in there?
    Sorry, I'm in New Zealand and we no longer have them for sale here. I think when they were a current model the thermoblock was about $200 to $250 but the price here is not helpful to you. You need to investigate the price through your local distributor.
Krups EA8080 Error 09
You need to contact the service agent.
Jul 31, 2018 | Krups Coffee Makers & Espresso Machines
I'm looking for an error code meaning that appear on my krups coffee machine the error code is "code error 02"
You will probably get some proper help if you identify the exact model. I don't expect "error 2" to mean exactly the same on every model Krups have ever made, narrow it down a bit for us please.
Mar 22, 2017 | Krups Coffee Makers & Espresso Machines
Error code 5 on Krups ea8080
During the first few seconds of pump running there is zero water flow. Either there really is no flow at all OR the flow meter is not detecting flow for some reason.
Oct 19, 2014 | Krups Cafe Express FMA110 Coffee Maker
Error code OA
Where do you get error OA on an XP4030, the machine does not have a display?
Oct 09, 2013 | Krups XP4030 Espresso Machine
During a cleaning cycle my krupa ea8080 bean to cup machine started leaking water from underneath the machine. After trying to make a coffee once it had finished, some coffee is coming out correctly, but...
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Mar 26, 2011 | Krups Small Appliances Espresso Machine
Error code oa will not preheat
you need to get to an authorized service center.
Try http://www.smallappliance.com/repairsmain.asp?cur=USD
Mar 04, 2011 | Krups XP7230 Compact Super Automatic...
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
I need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at [email protected] and I will reply to you with the manual in pdf format.
Mar 04, 2009 | Krups XP7230 Compact Super Automatic...
Error code OA
Error code "OA"....machine thinks it has a faulty Laser unit. You can try a reset ( Menu, *,M..press ENTER.) if it resets GREAT.
If not and the code comes back,most likely Laser unit is defective.
Expensive and time consuming repair.
Sep 05, 2008 | Muratec MFX-2500 Plain Paper Laser Fax
Coffee Makers & Espresso Machines Logo
427 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
