My samtron monitor working fine...just problem is that i cant adjust screen sizemGeometry,now its showing rounded cornerns of every window..even horizantal,vertical postion not proper..will u plz assist me regarding default settings of samtron
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
d problem is in a transistor costing little, situated near d monitor's
osd control ic (microprocessor), it is probably short....[refer the
connection n area around the front panel cn connector and crystal clock
generator]..beware u must b a professional
This problem is caused by the Novatek chip on the video board. Soldering a 50 Ohm Resistor across pins 5 and 6 of this chip resolves the problem on both the Samtron and the Samsung monitors. I have just corrected one of these last night by this means.
Hope that helps
FROM THE DESKTOP ON YOUR COMPUTER RIGHTCLICK on your mouse you wil get dropdown menu select properties tab then you will get display properties menu select the settings tab and adjust the sliding control to increase screen resolution to fit your monitors screen if this doesnt work you may want to have a video graphics card installed in your computer.
