20 Most Recent Samsung SyncMaster 793MB 17" CRT Monitor Questions & Answers
i want vga cable D connecter connection
mainly vga cable broken that why i purchage one emitty d connecter scoket so i soldering this connection plz
Samsung... | Answered on Dec 02, 2019
how to solve this?
Samsung... | Answered on Aug 29, 2012
You will need a service manual to get the correct part number, I tried to cross with my NTE data base no luck, went into ebay site punched in the original numbers came up empty.
Samsung... | Answered on May 03, 2012
Firstly try plugging the power cod from your PC into the monitor and power it on. Are there any LED lights on your monitor? If there is, then all you need to do is replace the power cord with a new one.
If there aren't any, it means that your CRT's internal power supply unit is dead and needs to be replaced. However, replacing these parts can be quite costly and involves labor charges since your monitor is out of warranty. I highly recommend that you look into the option of purchasing a new LCD monitor as these are pretty cheap nowadays.
Anyway, here is the service centre in Bangalore dealing with Samsung monitors:
#8 WOC Road, Mahalaxmipuram Post Near Swathi Hotel, Bangalore - 560085 KARNAKATA
Phone : 23496985
Samsung... | Answered on Mar 11, 2011
you may have locked the OSD (on screen display for adjustments)
Press and hold the MENU button for at least 10 seconds to unlock it.
Samsung... | Answered on Feb 24, 2011
Hi there please press the side button ( Menu) from there you can make the screen color default. Thanks you.
Samsung... | Answered on Dec 03, 2010
You are missing Blue color, it is either you have bent pins on the VGA cable or your monitor lost the Blue Gun Driving circuits (located on the PCB on the picture tube).
http://s807.photobucket.com/home/budm/allalbums
Samsung... | Answered on Jun 04, 2010
Cannot adjust brightness cause by inverter Board problem. You can send it to computer shop or TV shop to replace it. Because the CRT and CRT TV use the same tech.
Samsung... | Answered on May 11, 2010
If your computer doesn;t have Built-in Card Slot(s), then you must get a USB - Memory card adapter. I have included an Ebay link so you can see what I mean.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+-+memory+card&_sacat=See-All-Categories
Then, you simply install the USB device and drivers. After which, you plug in the memory card to the USB adapter, the card will then show up as a "Drive" as such it can be used as normal, ie: Cut-Copy-Paste. The pics can then be used either straight from the Card, or copied somewhere else on ya PC, say desktop, and use them from there.
Samsung... | Answered on Jan 19, 2010
If you get a display when you first turn on then after, say, 10 minutes it goes blank, your power settings could be too low. Does it come back if you wiggle the mouse?
If you go into Start/Control Panel/Power Settings you should see a "Power off monitor" or similar. Either turn this to a longer time period or set to Never. The last option isn't going to do your electricity bill any favours though.
Samsung... | Answered on Dec 16, 2009
use the F8 menu, select ENABLE VGA MODE that will force a 640 x 480 resolution for that boot.
Samsung... | Answered on Dec 04, 2009
If you have on laptop the vga exit, no problem, the VGA cable just works fine.
Samsung... | Answered on Oct 13, 2009
hi,
I think there is problem with your display card.
If you could try testing with another monitor you ll get confirmed. In that case you have to purchase another VGA card and install it then it works fine.
Regards
Samsung... | Answered on Oct 03, 2009
time to replace the monitor, u fried the board, been there done that
Samsung... | Answered on Jul 25, 2009
the VGA cable connecting from moniter to the computer is faulty so replace new
Samsung... | Answered on May 29, 2009
Samsung SyncMaster 793MB 17" CRT Monitor Logo
37 questions posted
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
default colour setting
  • Computers & Internet
