When you change the drum you must reset the drum count.
1: press ONLINE button once. The lcd display will read offline.
2: press MENU button until the lcd display reads MAINT. Menu.
3: press ITEM+ button twice. The lcd display will read drum count reset.
4: press SELECT button once. this will save the drum count reset.
5: press ONLINE button once. You will notice the Change Drum Message
has disappeared. You should be able to print at this time.
Good Luck
Brother
strongly recommends that customers use only genuine Brother drum units and/or
toner cartridges. Each Brother laser printer is designed to work at pre-set
temperatures that are matched exactly to each of our individual toner
formulations. Each individual component is designed to work with the other
to ensure quality and reliability. Using non-Brother supplies may affect the
hardware performance, print quality and machine reliability. The Brother limited
warranty does not apply to any problem that is caused by the use of third party
drum units, toner cartridges or toner.
For
LIGHT print continue to STEP 1.
For
BLURRY, VERTICAL or HORIZONTAL LINES, SMUDGES OR DOTS continue to STEP
4.
1.
Check the Toner Save setting. If this setting is programmed on, all printed
documents will be light.
a.
Press MENU, 1 (General setup), 6 (Ecology), 1 (Toner
Save).
b.
Press the UP OR DOWN ARROW key until the display reads "Toner Save:
OFF".
c.
Press OK.
d.
Press STOP/EXIT.
e. If
the setting was changed from ON to OFF print the User Settings list by pressing
the REPORTS key and then 5 (User Settings).
