Both players should play a tape. In fact the player can be set up so when tape player 1 finishes the tape, player 2 will kick on to play the other tape by itself. Only one is the recorder to dub another tape or record CD to tape.
8 mm and the newer super 8 mm video tapes are different. You can't use super 8 mm in old player. And old tapes won't play well in new super 8 mm players. Like Sony!
I have the same problem. I just bought a sony handyman and tried to play my old tapes and nothing, not even sound. But I just recorded something using an old tape and it records and I can play that back. I'm thinking maybe over time, somehow all the data on there got erased. Which is really a bummer.
It is possible the tape loaded on the wrong side of the drive. If you romove the tape, look for slack and tighten up, try it again or another tape. Otherwise it is likely that a spring for the pressure roller is off or broken. This is not easially repairable.
I think my Hi8 tape was magnatized I had 3/4 of the cassette taped I played it back once and when I went to play it back again I got a blue screen. I went to the local camera shop where we played the tape on his camera and we got intermitent static but no video. My canera is a Sony DCR-TRV260
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
Stop the tape.
Ensure the tape has been rewound to the beginning of the video recording.
Play the tape.
If the issue is not resolved, stop the tape and remove it from the camcorder.
Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
Reinsert the tape into the camcorder.
Play the tape.
Insert a different tape with video footage into the camcorder.
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Tapes may be played back by the camera itself. If the tape was shot in the 720P (HD) or 480P (SD) modes, it cannot be played back on a standard DV VCR or camera. Tapes shot in the 480i (DV) mode are completely compatible and can be played back on any DV VCR/camera. In addition, tapes can be dubbed to a JVC HD DVHS VCR via the firewire connector.
