"Out of range" message indicates that the output from your computer to display it from your Samsung HLR5064W DLP TV is too large. You need to adjust the screen resolution settings for you TV. I have attached images of display settings dialog boxes from different versions of Windows.
You may open the display settings of your computer by clicking on START > CONTROL PANEL > DISPLAY. While your TV is connected, click on IDENTIFY button. You will notice that numbers 1 and 2 will appear briefly on your screens consecutively. As the dialog box shows 2 monitors with numbers 1 and 2, click on the monitor with "2" on it. Then, adjust resolution to 1280 x 720 as this is the highest resolution your TV can handle. You may adjust the TV (monitor #2) to be IDENTICAL or to EXTEND the display of your computer. You can also assign it as the main monitor but not recommended. Click OK then try to toggle your computer's display. You should be able to see a display from your TV this time.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
