20 Most Recent Samsung HL-R6168W 61" HDTV Questions & Answers
A suggestion: if replaced the wheel--there are two cables from it to nearby metal box---one is conventional but can be hard to plug in---the other is a ribbon cable----IT ONLY HAS CONTACTS ON ONE SIDE WHERE IT PLUGS IN AND CAN BE INSTALLED BACKWARDS--contacts usually face the rear of the set.
Samsung... | Answered on May 30, 2012
I think your problem is going to lead back to the DMd Moduel Located in Front of Color Wheel
The Color Wheel you order was it PN# BP-01103A?
Encompass Parts Distribution List this Model and also has Free Service Manual that you can Print out . HLR6168Wpdf.
Samsung... | Answered on Jul 01, 2011
Tv projection lamp been inside this tv like 1 1/2 or 2 years already and tv it is on daily used it like 4 or 5 hrs every day?Yes,than the tv projection lamp live are ending already and the causes.
Samsung... | Answered on May 26, 2011
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Samsung... | Answered on Apr 30, 2011
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Samsung... | Answered on Mar 02, 2011
You may have a couple of problems.The shading is probably caused by a defective light tunnel, Samsung is covering the cost to repair this problem on certain models. You can call 1-800-samsung to find out if it is covered. The noise and color distortion sound like the color wheel is also beginning to fail. Both of these components are inside the light engine and I would recommend not trying it yourself.
Samsung... | Answered on May 24, 2010
thats a tough one i could be a few things but not bulb or it wouldnt light up, were do u live?
Samsung... | Answered on May 07, 2010
If you can see video thru the shaded bar it is a light tunnel shifted in the optics --
Samsung... | Answered on Mar 17, 2010
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Samsung... | Answered on Jan 28, 2010
Reset all video setting to factory setting,should back to tv set.Same prob.ur video board have prob.must change.
Samsung... | Answered on Nov 14, 2009
Take it back,the video board have prob.Not thing to do with HD,HD only change mode to 1080i.
The color wheel has shattered. Probably a bp94-1579 or such. About a 300 dollar repair or so in home, not hard to do for a decent tech.
Samsung... | Answered on Oct 31, 2009
Yes,it the colors wheel and it chasis not very good fit for long period of time,must change the flaw in design in this model.Might have to change again furture of the tv.
Samsung HL-R6168W 61" HDTV Logo
Popular Tags
28 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
our three year ol samsung
  • Televison & Video
