SanDisk Sansa Clip MP3 Player Logo
Posted on Feb 20, 2011
Hi, my 1GB Sansa Clip dosent work right. when i connect it to the computer (Windows 7), the lights came on and it showed that it was connected, then it switched to writing and it just froze from there. And the computer says device driver software was not succsesfuly installed.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
115
Points
6
This may or may not work but if your music etc. files are on your pc, then delelte them from the player and once you do so, reload them, this has worked for me in the past
3helpful
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix.
Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61
Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware
NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
2helpful
2answers
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Can't find clip in my computer
This is and excerpt from "EphMusicFan" on the Real player forum. Original link is also below.
" The following steps finally fixed everything for me. While it may seem long, it only takes about 15 minutes and should fix everything.
If you run windows XP don't have Windows Media Player 11 installed, download and install it here,
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
Run Windows Update, and install all high priority and optional updates related to Windows Media Player or device synchronization.
On XP, the updates include:
Update for Windows Media Format 11 SDK for Windows XP (KB929399)
Security Update for Windows Media Player 11 for Windows XP (KB936782)
Update for Windows Media Player 11 for Windows XP (KB939683)
Security Update for Windows XP with Windows Media Format Runtime 9.5 and 11 (KB941569)
Open Rhapsody
From 'My Account' menu select de-authorize computer
Close Rhapsody
To delete the mcs.rma file:
1. Close RealPlayer/Rhapsody
2. Click the Windows Start button. Then click Run.
3. Type %windir%\system32\ and click OK.
4. Find the mcs.rma file.
5. Right-click mcs.rma and select Delete.
6. Close the window.
To delete the basi3260.dll file:
1. Open the My Computer icon on your desktop.
2. Open the C: drive (usually Local Disk (C:\)).
3. Open the Program Files folder.
4. Open the Common Files folder.
5. Open the Real folder.
6. Open the Plugins folder.
7. Find the basi3260.dll file.
8. Right-click basi3260.dll and select Delete.
9. Close the window.
10. Restart your computer.
on sansa Clip itself, disconnected from computer, go to settings, then choose format
Make sure Rhapsody, Windows Media Player, and all other media programs are closed
download firmware
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=2946 (make sure you get 'Americas' firmware version)
unzip firmware file
connect to computer
drag firmware file onto sansa Clip icon in Windows explorer
wait to finish all copying (Sansa Clip screen will say connected, not writing or reading)
disconect
firmware updates on device, then it shuts off automatically
turn it back on
reformat from device (settings menu, format)
put in msc (under USB mode on settings menu)
reconect
open sansa Clip E:/ in Windows explorer, delete all files (should be 6-8 folders and files in top level directory of Clip)
reformat from windows explorer (right click, format, (FAT file system, NOT FAT32))
disconect
put in mtp (under USB mode on settings menu)
Open Rhapsody
It will run through quick setup again, due to files deleted before.
'Reathorize Computer' (under 'My Account' menu)
"Update Track Licenses' (same menu)
connect to computer
wait for Rhapsody to fully load clip (may take 30 seconds)
reformat from rhapsody (right click on sansa clip icon in rhapsody, select reformat)
hold down control and shift buttons at same time, right click on sansa clip icon in Rhapsody, select 'reset secure clock'
right click on sansa clip icon in rhapsody, select authorize device
wait while sansa clip updates (wait for screen of device to say 'connected' for a while, rather than writing or reading)
disconect
reconnect
wait a while updates finish
disconect
verify acount, and dates on device, under setting menu, account
should say renewed (with today's date) expires a date 30 days later.
download one new track from rhapsody you never have downloaded before
reconect
transfer that one track to clip
wait for all updates to finish
disconect
verify account, dates on device, check that the track plays properly"
Hope that helps.
http://real.lithium.com/real/board/message?board.id=InstallingRhapsody&thread.id=26724
Windows Media player will not "Connect a Device"
Make sure the hold/lock is not engaged.
Try a different USB port.
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
3answers
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
i tell you connect to the computer your device
and right click on your device and format it
Sansa clip mp3 player
check drivers in xp or windows
do u have drivers cd ,
download drivers n install it.
ur's kishore chowdary +919441133420
Brand new Sansa Clip not recognized in My Computer
Reformat and upgrade the firmware
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
FIRMWARE UPGRADE - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
10helpful
8answers
Does not recognize
Comment by vickisanchez, posted on Mar 19, 2008 IT FINALLY WORKS !!!!
Sandisk Tech support had me do the following:
- Turn it OFF
- Put it in the HOLD position
- HOLD the center button IN while plugging into USB port, continue to hold for 5 to 7 sec even after plugged in.
At this point MY COMPUTER recognized it. And it worked.
He also had me to:
- go to WWW.MICROSOFT.COM
- In the upper right hand search bar, type in MTP PORTING KIT
I did this and downloaded the first one. Now my Sansa Clip work perfect. I wish I would have talked to him last week before I returned the last one, for the same reasons.
If this does not help call the 1-800 # , opt #4, and ask for GUY (yes that is really his name) out of 5 or so calls to Tech Support he is the only one who knew what he was doing, and how to actually HELP.
GOOD LUCK
Scandisk 1gb
There could be several issues here.
Is the computer showing the Sansa as plugged in?
Does Windows Media Player show the Sansa as plugged in, or does WMP say "Please Connect a Device"?
Are you running Windows Vista or windows Media Player 11? If so, grab the Firmware update from Sansa's website at: http://www.sandisk.com/Retail/DriverDownloads.aspx
If the player keeps freezing while plugged into the computer, you may need to Format the player in Windows Media Player 11 after performing the firmware upgrade. This will erase all of your songs off the player, so you will have to reload them. But your player will work fine after that.
-Tha Mp3 Doctor
134helpful
13answers
- Turn it OFF
He also had me to:
GOOD LUCK
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
