Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Yes it can be saved, it is indicating the fuser thermister is open or below temperature. Try opening the printer and restarting it. If that does not fix it you may have to replace the thermister or the fuser
It points to an internal error. It may be from the fuser unit. Make sure all the wires are connected praoperly and that you didn't disconnect anything when you repalced the fuser. If the problempersists, you'll have to take it in for service.
unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
