Just brought a fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Posted on Jan 08, 2015
SOURCE: fatal error 173?
It points to an internal error. It may be from the fuser unit. Make sure all the wires are connected praoperly and that you didn't disconnect anything when you repalced the fuser. If the problempersists, you'll have to take it in for service.
Posted on Aug 22, 2009
SOURCE: oki b4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Posted on Feb 24, 2010
SOURCE: hello i'm french, i have
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
Posted on May 27, 2011
Jul 06, 2015 | Oki Electric Industry MC860 AllInOne Led...
May 27, 2011 | OKI C8800dn Led Printer
Apr 26, 2010 | OKI C5650n LED Laser Printer
Jan 18, 2010 | OKI C3200n Led Printer
Aug 20, 2009 | OKI C5150n Led Printer
Jan 30, 2009 | OKI C3200n Led Printer
Jan 27, 2009 | OKI C5100n Laser Printer
Nov 19, 2008 | Office Equipment & Supplies
Sep 14, 2008 | OKI C3200n Led Printer
Aug 10, 2007 | OKI C5150n Led Printer
May 29, 2014 | OKI C3200n Led Printer
Apr 08, 2014 | OKI C3200n Led Printer
Jan 08, 2014 | OKI C3200n Led Printer
550 people viewed this question
