SOURCE: Epson Photo RX620: Printing Pink Lines
None of these answers are accurate. I know precisely what your problem is, and you aren't going to like what I have to say. What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer. I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue. I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem. The issue you are having is with the Epson print head, which uses piezo technology. What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber. It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet). Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture. Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy. The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head. It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head. Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it. If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not. Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol. However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed. If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours. If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem). The solution is to acquire a new print head. Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer. Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge. Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy. Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
SOURCE: Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
SOURCE: Hi, I have an Epson Stylus
print head clogged..if you remove it try cleaning it...or sink it in a boiled water to released clogged.....used tissue on cleaning...maybe its effective coz i repaired same printer you have...
SOURCE: CX6600 Epson - prints blank pages
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
To remove and install only the Printer Driver for your CX6600, please perform the following steps:
Driver Removal
1. Go to START then SETTINGS and click on CONTROL PANEL ( START and CONTROL PANEL in Win XP) and double-click ADD/REMOVE PROGRAMS.
2. To remove the printer portion select EPSON PRINTER SOFTWARE and click on REMOVE. Ensure the correct printer model is selected on the uninstall utility.
3. Click OK and follow the prompts. If asked to confirm removal of any personal settings or shared files, click YES or OK.
4. Once the components are removed, power off your unit and disconnect the USB cable.
Installation
1. Go to http://support.epson.com
2. Under Welcome to Epson Support click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Download the most current driver for your printer and operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it is easy to find.
5. Once download is complete, close your internet browser. To install simply double-click the file you downloaded and follow the prompts.
6. Do not reconnect the unit until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer. Installation should complete automatically.
SOURCE: Epson Nozzle check
hi sandysun,
try to deep cleaning at you nozzle from printer software at printer properties..it should help..
if still the same problem...u printhead got problem...try to take out you print head..put in the hot water..becarefull dont wet the chip near the print head
