Whirlpool GGQ8831L Gas Dryer Logo
Posted on Feb 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an older Whirlpool Ultra Care II gas dryer. I used a dryer brush to clean out the lint area and now the dryer is making a very loud noise when it runs. I get heat but sounds like it is going to explode.
  • hillaryga Feb 07, 2011
    I have a repairman coming on Wednesday but have wet laundry. Can I run the dryer safely?
    Not sure if this already posted. Can I run the dryer - I have a wet load of laundry and the repairman is not coming until Wednesday.
Anonymous
Level 3:
  • Whirlpool Master 1,902 Answers
  • Posted on Feb 07, 2011
Anonymous
Whirlpool Master
Level 3:
Answers
1902
Questions
0
Helped
533872
Points
5669
Hello & Welcome to FixYa
The loud noise that you hear is from the belt that is either broken or worn out, you can check this picture....part#30 is the belt that needs replacement. Also check the idler pulley (part#13) and motor pulley (part#29). Please get back to me if you have any other questions.
Kevin
  • Anonymous Feb 07, 2011
    I dont think it is safe to run the dryer.
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
2helpful
2answers
Bosch Nexxt 500 series gas dryer lint building up inside dryer
Get a long brush they have ones made for this chore proably at Ace hardware.
Aug 06, 2009 • Dryers
How To Open Bottom of Dryer
Take the back cover off and there is a compartment that hook to the hose, with the right tools you can pull the compartment out and clean it to include other parts showing. hope I helped allittle.
Whirlpool gold utra care II gas dryer does not dry
That has to be a stopped up vent or a lint filled dryer. You gotta clean out the lint, open the vent.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 27, 2008 • Dryers
26helpful
6answers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
1helpful
Whirlpool ultra careII washer
could beyour motor has these have carbon brushes and if theyve gone too low can cause your motor to burn out check thecarbon brushes which are held in place by 2 star screws held in a plastic casing if these are low could be that you need to replace the motor,motor bearing could be damaged m8
Lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
