Ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
You can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" is not .It is an optional unit.after that you can make double sided copying.
