20 Most Recent Canon IMAGERUNNER 6570 Copier Questions & Answers
hi this is srinivas
sir
canon 6570 when machine is switch ON error E000004-0103 and sometimes E000004-010 appears , what is the reason?pls giv me a solution.
thank u
Canon... | Answered on Dec 15, 2018
Its on the rear bottom right, I believe there is two screws, remove the panel and take out the bottle and empty it. After replacing the waste toner case or removing the waste toner from the case, clear the toner counter in service mode as follows:
To get into service mode, hit additional functions[*] 2&8 follow by additional functions[*] again. [Select [COPIER> Counter> MISC> WST-TNR], press "C" (Clear key) to clear the counter, and turn the power OFF/ON.
You can also change the detection level as follows:
The waste toner detection timing is determined by the total page counts specified in service mode below:
1. Page counts until the warning message is indicated
2. Page counts between the warning message and E013 indication
Field Remedy
Follow the steps below if you want to change these page counts:
In service mode [COPIER> Adjust> MISC> WT-FL-LM], select any number from "0" through "4".
0: 80,000 / 1: 140,000 / 2: 210,000 (default) / 3: 320,000 / 4: 460,000
In service mode [COPIER> Adjust> MISC> WT-ER-LV], select any number from "0" though "3".
0: 1 / 1: 20,000 / 2: 40,000 (default) / 3: 60,000
Canon... | Answered on Oct 10, 2017
sir
canon 6570 error code E000121-0001
Canon... | Answered on Sep 03, 2017
how to solve this problem for e 121..even i try change the fan ,dc con ,power supply board,reader controlled board and main con also same...ps help
Canon... | Answered on Apr 03, 2017
1-the scanning lamp is not coming on
2-seperation is not working properly
3-the HVT for the seperation is not working
Canon... | Answered on Aug 15, 2016
Additional Function>Communication Settings>TX Settings on left>Edit Standard Send Settings>File Format>Select PDF or Tiff>OK>Done>Done>Done
Canon... | Answered on Oct 09, 2015
A E00100 means you have a laser problem. You may have a bad laser? Also, I would make sure the cover for the Primary charge is on correctly. There is a lever that gets pushed in to turn the laser "ON"
Canon... | Answered on Jun 01, 2015
code for changing LTR to A4
*28*
copier
option
then goto CST
change reading from 18 to 6 in both
it done
Canon... | Answered on Jul 23, 2014
check the pre-transfer corona assembly, there's some problem with the shutter
Canon... | Answered on Jun 23, 2014
that was feeding motor problem, in the motor chek the fuse or replace the motor
Canon... | Answered on Jun 11, 2014
At power-on, the connection of the
developing hopper toner sensor is not
detected.
Canon... | Answered on May 03, 2014
214 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
get code e000020 02b1 das anybody know
  • Office Equipment & Supplies
