When you sear meat all you are doing is cooking the outside at high temperature so a caramelized crust forms. To do this on a gas grill turn all of your burners on high, close the top and let the grill get very hot, I usually shoot for around 400 to 450 degrees. When you put the meat on the grill do it fast, directly over the heat source and close the top to keep the heat up. You'll have to experiment but usually about a minute and a half to two minutes per side is all it takes. You want the meat to be thoroughly browned on the outside. Now turn the heat down or off on one side if your grill is set up for that, flip the meat and cook it slowly on the side of the grill that's turned off or over indirect heat to your desired done-ness. This will depend totally on the thickness of your meat, again experiment. Another important step is to let the meat stand for five to ten minutes after taking it off the grill. This keeps all the juices from running out of the meat the first time you cut into it and ending up on your plate.
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
