20 Most Recent
Karcher K5.540 2,000 PSI 1.4 GPM Electric Pressure Washer Questions & Answers
Electric pressure washer will not start
CLEAN FRESH WATER IS IMPORTANT FOR THESE PUMPS, I ALWAYS USE A HIT OF ARMOR ALL IN THE PUMP AFTER USE . YOU MIGHT SEE IF IT'S GETTING POWER TO THE MOTOR MIGHT HAVE A BAD GFIC ? PLUG IT IN PICK UP THE UNIT AND TRY DROPPING IT FROM A FOOT OFF THE GROUND, THIS JAR MIGHT SHOCK IT BACK TO LIFE ?. Jay the pool pump whisperer FLORIDA 32750
Karcher window vac screeching when turned on. Why ?
If you can hear the vac squeaking as you run across the window, you've just not applied enough liquid. Just go over the window again with the spray bottle and microfibre cloth and then vacuum the liquid away.
Electric Pressure Washer Wont Turn On
I had the same problem. I removed the spray part of the spray gun so I was on soap setting and I had water but when I reconnected the spray wand same thing.
* I turned out to be a little bit of grit was in the nozzle. I cleaned out the grit and my spray cleaner worked without a problem.
