Where can we buy the kit?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Link to Weber grill information:
https://consumer-care.weber.com/hc/en-us...
SOURCE: converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
SOURCE: converting an amana natural gas dryer to propane
heres a conversion kit for you 649P3 . comes comple with instructions,,, natural to lp gas
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
SOURCE: Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Converting Weber Genesis Silver B from LP to Natural Gas
Hello...I have the same grill and want to do the same conversion...From my research, you need to drill out the three orifices with a size #53 wire gauge drill bit. ( this resizes each orifice to 12000 BTU's each, which the grill is rated at 36000 BTU's).Then remove the existing hose and regulator. Replace the hose with a Quick disconnect compression fitted hose. The NG supply needs to have a pressure regulator installed, with a shutoff and quick disconnect fitting installed. Connect the hoes from the grill to the supply, and fire it up...THIS IS WHAT I INTEND ON DOING TO MY GRILL,BUT YOU DO THIS AT YOUR OWN RISK>>>
