The error code E000021-0400 on a Canon C5240A typically indicates a problem with the fixing assembly temperature sensor. The fixing assembly is the part of the printer that fuses toner onto the paper, and it relies on a temperature sensor to ensure that the temperature is maintained within a certain range.
The specific error code E000021-0400 usually indicates that the temperature sensor has detected a problem with the temperature reading. This could be caused by a malfunctioning sensor, a problem with the wiring, or a problem with the fixing assembly itself.
To resolve this issue, you may need to replace the temperature sensor or the entire fixing assembly. However, before doing so, you can try resetting the printer by turning it off and on again. If the error persists, you may need to contact a qualified technician for assistance.
You can easily identify when yourcomputer system gets infected from viruses. Some of the signs of virusinfections are enlisted herewith:•Computerbecomes very slow in performance. •Suddensystem crashes and computer reboots repeatedly. •Applicationsoftware crashes and random messages are displayed on the monitor. If you find any of the above mentionedsign on your computer system, then there arises the probability of yourcomputer being infected with viruses. The next step after detecting thepresence of virus on your PC is to remove them from your system in order tosave your important data. If your computer is not infected with any type ofmalicious software then it is strongly recommended to install any bestantivirus software to keep it safe against the attacks.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */
table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt;
font-family:"Times New Roman"; mso-ansi-language:#0400;
mso-fareast-language:#0400; mso-bidi-language:#0400;} Unlocking your phone free contains simple steps which are as
follows:
Download Nokia Free Unlock Codes
Calculator to the computer. Double-click on the
downloaded file to install the program.
Double-click on the installed
program. A window should pop up with several options.
Choose the make of your phone from the list given. Choose the model number.
Press *#06# on your cell phone.
Press "OK". A number should be
displayed on screen. This is the serial number of your
phone, also known as an IMEI number. Enter this number in the IMEI field in the Nokia Free Unlock
Codes Calculator window.
Select your country from the list
in the "Country" field. Select the name of your cell
phone network from the list given. Press "CALCULATE". A
list of unlock codes should be displayed in the
window.
Replace the SIM in the locked phone with the one that will not work. Turn on your phone. A message indicating "Invalid SIM"should be displayed. Enter one of the unlock codes and press "OK". Your cell phone should be unlocked by now.
The Toner Supply Screw Rotation Sensor detected rotation error within the specified period of time.
Remedy
[Related parts] R1.01 - Harness between the Feed/Drum Driver PCB (UN2/J225) and the Developing Motor (Bk) (M8/ J6011) - Harness between the Feed/Drum Driver PCB (UN2/J212) and the Toner Sensor Relay PCB (Bk) (UN42/J1430) - Developing Motor (Bk) (M8) - Developing Assembly (Bk) - Main Drive Assembly - Set-on Hopper Assembly - Feed/Drum Driver PCB (UN2) [Remedy] Perform the following in the order while checking whether the error is cleared. 1. Check that the Developing Coupling of the Developing Assembly is not damaged. 2. Check that the Developing Coupling of the Main Drive Assembly is not damaged. 3. Check/replace the related harness/cable, connector and parts.
1402 is the unit not detecting the USB stick inside (behind left vent) which it uses as a data logger. You can still run it like this. 0400 is one or both condenser fans are not spinning. Check the 15A fuses near the power management module. Could also be a broken wire.
.What's your phone Brand and model? If you forget the phone security password then try default code like 0000 or 1234 to reset it .If it doesn't reset your mobile then visit Unlocking4Free.com here they provide master reset code for some Nokia DCT phone and Alcatel old mobile models at free of cost.Using this code you can reset your mobile and again set a new password.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
this error code means the exposure lamp has failed and will have to be replaced. you can try to reset the error code but if it comes back the lamp will have to be replaced.
to reset the error:
1.open the front door with the machine left on
2. locate a small square hole inside the front door towards the bottom right.
3.insert a small object such as a small ball point pen to actuate a error reset switch the screen will indicate the front door is open when the switch is actuated.
Apparently the latest software doesn't work with Leopard 10.5.2. I uninstalled the Epson software and installed the earlier version [driver version 3.88] that come on the Installer CD with the printer. Printing now works.
