SOURCE: Sony DCR-TRV 250
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
SOURCE: Transfer to Computer?
yes all you need is intervideo windvd software...or you can use movie maker from window xp sp2
SOURCE: sony handycam dcr-trv19e mini
Thank for that qestion,
At this point, if you are a lay-man or person you need to eject the camcorder and aloud it open and put under sun light for an hour. If its do the same, take it to a technicain.
but if you are a technicain, dismantle the camcorder and put the machinusm under hot tempreture for 20minute. then mount it back and your camcorder will be fine.
I have done this time and again and it has never fail me.
I hope you will smile.
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
