SOURCE: I am trying to print
The tray itself should have tabs on the side telling the type of paper look at those and see if there is anything broken off.
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
SOURCE: i have a phaser 8560mfp. screen says job requests
please double check and
Ensure the paper tray is
correctly set and that the the paper type is set correctly in the front panel.
SOURCE: Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
SOURCE: Printer says paper jam, but no paper is jammed
Check the following information.......
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
or
most of the time for a paper jam, there is a QUEUE of papers waiting to be printed. id take out the usb cable via the back of the computer {the one that connects to the printer} go into the control panel, look for printers, double click on that, find the printer, it should say {working offline} right click that, choose the uninstall/delete opts. turn off the printer. reboot the machine, wait until it boots all the way up. take the printer, turn it on, then plug back in the usb cable to the back of the machine. if it is windows either xp/vista it will auto find the usb cable and install automatically. you can then go back to the control panel, printers and it should be listed in the directory. try to right click go to properties of the printer and do a TEST PRINT, should print out.
