20 Most Recent
Xerox Phaser 7400DN Laser Printer Questions & Answers
have you run the maintenance ie. clean printer head and print a test page this will usually give you an indication as to what could be faulty .
Xerox Phaser...
Answered
on Oct 31, 2016
What part did you replace? Can you still print to it? What model is it?
Xerox Phaser...
Answered
on Jul 07, 2015
Hi Rich,
Thank you for your lengthy and informative question that does help.
My first thoughts:
Did you try and tell the driver what particular type of paper you wanted to print on such as none Xerox recommended.
A thought just occurred if you were wanting to print transparencies then the printer would have to print strong colours at 100% because once you place the image on a OHP the image would look really washed out.
All the Xerox printers I've ever worked on don't have sensors that look at the opaqueness of the media, they do however have transparency sensors because once the edge of the paper has been detected a jam could occur, so lever type sensors are used to actually feel the media.
Good luck.
Xerox Phaser...
Answered
on Jul 06, 2015
Hi Kath,
I expect you have it sorted by now.
I think you might have had one off the developer tanks stuck or broken. If the developer roller does not turn then the colour quickly fades along the page. If you tried to do a test page and that was good then there was nothing wrong with that side of things.
Good luck.
Xerox Phaser...
Answered
on Jun 02, 2015
Check the Xerox.com website and follow the links for assistance.
Good luck.
Xerox Phaser...
Answered
on Mar 08, 2015
Is your printer set to Economode in the printer settings? It may be and so its printing at low quality.
Xerox Phaser...
Answered
on Jul 16, 2014
Are the streaks evident when printing actual images? I was told by an experienced Xerox service tech that those solid-fill test pages can be misleading -- mine does the same but prints photos beautifully. I suggest printing some full page photos, check for the streaks. You've already done just about all you can.
Xerox Phaser...
Answered
on Jun 20, 2014
That most likely would be a broken paper exit actuator.
Xerox Phaser...
Answered
on May 26, 2014
My copier is not able to operate because of Dept ID and password. So, can you suggest ways to remove the Dept ID and Password?
Xerox Phaser...
Answered
on Jul 17, 2013
No this is phisically impossible, try a larger sheet of paper and cut it
Xerox Phaser...
Answered
on May 29, 2013
Here is a website that has a list of the error codes:http://creatives.ro/downloads/Errors_Xerox_DC252.pdf
Xerox Phaser...
Answered
on Apr 03, 2013
