Posted on Nov 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please, some solutios for the failure f8 I need, air condicioner 12000 btu
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on Nov 21, 2010
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10845528
Points
101584
The F8 code usually is because of a low charge condition...get the unit checked for leaks and recharged...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Idylis 12000 btu manual
Find more information on this link:
http://pdf.lowes.com/useandcareguides/840206110031_use.pdf
1helpful
What extension cord should i use on window ac unit model number ASW12ALS1 12000 btu
http://www.appliancefactoryparts.com/search/part/1042383/116404 this is a link formthe extension cord you need.
HI there, I have a Goldstar WG1205R 12000 BTU window air conditioner that has no filter, blows slightly cool air and the fan power is very weak for 12000 BTU's How can I improve the performance of...
Sounds like you have a 220 volt air conditioner plugged into a 120 volt outlet.This will cause the conditions you are describing.
Put a filter on it please.
HOW MANY TONS IS THIS UNIT WEATHER KING 10AJA4801AH?
It's a 48,000 BTU AC - so 48,000 divided by 12000 = 4 tons
Note: 12000 BTU = 1 ton of air conditioning
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
The unit is not cooling the room. It is only comforting when you are in direct line of it.
you need to find out the size of the unit.
Rule of thumb - for every 600 sq ft of cooling area (in a well insulated house) you will need 1 ton of air conditioning. 1 ton = 12000 btu.
So, if your cooling area is 600 sq ft you would need an AC which was rated at 12000 btu, assuming your house is well insulated.
If it is not insulated well - you might need a bigger unit, i.e. 15000 btu.
1helpful
2answers
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Hi i have a Maytag 12000 btu Window ac unit that
I had a similar problem with my AC last week. These newer capacitors no longer have PCBs in them. The stuff they use now just ain't as good. As a result their are more capacitor failures tan ever. I would check that. If the cap looks swolen its probably bad.6f0f1c5.jpg52ae98e.jpgYou should also try and lubricate the motor. Use HVAC oil 106f87c.jpg$2 at Ace hardware store.
You gonna have to slide out the unit a little to get to the motor. Have rags ready.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
k24674
ADMIN Andrew
ADMIN Andrew
