HP DeskJet 5550 InkJet Printer Logo
Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is no icon on the taskbar, and I cannot figure out how to check the ink level.
Anonymous
Level 3:
Guru:
  • Master 731 Answers
  • Posted on Sep 24, 2010
Anonymous
Master
Level 3:
Guru:
Answers
731
Questions
Helped
328720
Points
2071
The HP Toolbox can be used to check ink Levels
  1. Right-click the taskbar printer icon .
  2. Click Open HP Deskjet 5550 Series Toolbox .
  3. Click the Estimated Ink Level tab.
  4. Check ink levels (estimate only, actual ink levels may vary)
Paper going through printer without printing,
Without more details it's hard to say, have you checked the ink levels? Double-click the maint.4.1.29.jpg printer icon on your taskbar (in the lower right corner of your screen). You will see the Epson status window. You will see the six ink cartridge icons and their ink levels. Click the "Information button" for more details about the cartridges. Hope this is of some help.
How can i check my ink levels
Hope this will help.
To check the ink cartridge status, do one of the following:
  • Double-click the printer shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar,
    Open the printer driver, click the Maintenance tab, then click the EPSON Status Monitor 3button.
Good luck.
How i check the cartage level, i am unable to doo that, plz help me...if have to any command direct to see ..please let u inform me..My printer is HP Clour Laser Jet 1600 ...
Check ink levels Use one of the following methods to check the ink levels. NOTE: If you have installed a refilled or remanufactured print cartridge or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable. Method one: Use HP Solution Center to check ink levels HP Solution Center is software that acts as a centralized point of access for tasks such as scanning, printing, and copying. The software is part of the software package that comes with your product. When you perform a standard installation of the HP software, HP Solution Center is automatically installed. You must have the full-feature print driver, which includes HP Solution Center, installed to use this method. If you do not have the full-feature print driver installed on your computer, you can install it now. Alternatively, you can use 'Method two: Check ink levels from the software program' to check the ink levels. Click this link (c02463264) (in English) to see instructions for installing the full-feature print driver and HP Solution Center.
  1. Open HP Solution Center.
    • Windows XP : On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista : On the Windows taskbar, click the Windows icon (c01364735.gif), click All Programs , click HP , and then click HP Solution Center .
    • Windows 7 : Click the Windows icon (c01364735.gif ), click Programs , click HP, and then click HP Solution Center .
  2. Click Settings , and then click Printer Toolbox .
  3. Click the Device Services tab, and then click the Estimated Ink Levels tab.
    or try this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00257147&tmp_task=useCategory&lc=en&dlc=en&cc=us&site=null&lang=en&product=390328&key=null
1helpful
How to check ink levels
Assuming you have all the HP drivers installed:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457163&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=3396080
  1. Make sure that the product is on and connected to the computer.
  2. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the Windows taskbar. The HP Solution Center dialog box opens.
  3. From the HP Solution Center , click the Settings menu.
  4. Select Print Settings and click Printer Toolbox . The Printer Toolbox opens.
  5. Click the Estimated Ink Levels tab to see the ink levels for the ink cartridges.
How do I check my ink levels
Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
Let me know if you have any other questions. Please rate this solution. Thanks.
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
    The Toolbox opens.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
HOW DO I CHECK THE INK LEVEL ON MY HP OFFICEJET 6500 PRINTER?
I would imagine there is a program running on the taskbar (bottom right hand corner) by hovering over the icons you will see notes as to what program the icon represents. if one corresponds to the printer then click it , have a look around in that program and you will see the ink levels.
if not click the windows start button then programs to look for the HP software.
3helpful
How to I check the ink levels on my printer? I have the hp officejet 6300. Help
Follow these instructions
  • Open HP Solution Center.
    • Windows Vista : On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 7 : Click the Windows icon (c01364735.gif ), click Programs , click HP , and then click HP Solution Center .
  • Click Settings , and then click Printer Toolbox .
  • Click the Device Services tab, and then click the Estimated Ink Levels tab.
    6helpful
    2answers
    How to reset the ink level of my hp officejet 6500
    Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
    • The exclamation mark (! ) symbol indicates a low ink level.
    • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
    Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
    1. Make sure the product is on and connected to the computer.
    2. Open HP Solution Center .
      • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
      • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
      • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
    3. Click Settings .
    4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
    5. Check the ink levels displayed on the Estimated Ink Levels tab.
    Figure 2: Estimated ink levelsc00670267.gif
    Ink levels
    1. Right-click the Printer icon on the Taskbar.
    2. Click Open Toolbox .
    3. check ink level
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
