Amazon Kindle 2 Logo
Max Whitlock Posted on Jul 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just downloaded a book and changed the screen from white to black. Then I dimmed the brightness all the way down and now I have a black screen. I cannot see the settings to adjust the brightness back to something I can see. I've downloaded other books afterwards and they maintain the black settings that I have so none can be read. This is obviously not idiot proof. Any ideas on how I can correct this?
cwradio73
Level 3:
  • Master 1,162 Answers
  • Posted on Jul 22, 2017
cwradio73
Master
Level 3:
Answers
1162
Questions
0
Helped
363899
Points
3460
It all depends on the generation of Kindle you have. On mine I swip down from the top of the screen an the lighting an settings come up. Maybe this will help. Mine is 5 generation. On my earlier one it was different.
Nextbook NX16A10132S Brightness Setting Won't Work Correctly.
Try to do it opposite way round or go to setting a display
RCA tablet too bright
Swipe down from the upper right corner. In the middle of the screen, you may see a button appear for a few seconds, tap it. It may give you access to a slide with which you can adjust the brightness of the screen up or down. If you dim it too much, you may not see a screen! Here is a page showing how to increase brightness. --However, it should serve to show you where the controls are.
http://www.instructables.com/id/Fixing-lost-brightness-on-an-RCA-tablet
1helpful
Screen too dark
go into settings and look for personalisation the change your background if that dosent work its probably on night mode or you have it on auto set
When I go to text portion using kindle books, the page dims even if the brightness setting is at max
The option to keep the display bright is not found under settings in the Android app, but under the font settings. If you tap the centre of your screen whilst reading your book the icons will appear at the top of your screen. Click the font size icon, and a drop down list of settings will appear. The one at the bottom deals with brightness.
I'm not able to adjust screen brightness on my kindle - there is no lightbulb icon in the tool bar. I'd like to read at night, is there a way to adjust screen brightness?
Is the Kindle a Paper White version, or akin to the original Kindle version? If so, there is no backlight, so no screen brightness adjustment. You'll have to do the screen brightness adjustment like you would for a book.
2answers
I was changing the font on google play books and hit a background or something. Now I have a black screen on all books. Can't get regular screen back.
Triple tap anywhere on the page and the brightness control should show. Uncheck auto if it's checked and move the slider to the right.
How do I make my kindle fire screen brighter?
Adjusting Screen Brightness The screen on the Kindle Fire uses more power than anything else, and the brighter the screen, the more battery power it uses. To increase battery life, you can lower the brightness of the display.
Unlock the rest of this book. Swipe the status bar down to open the Settings drawer.
Unlock the rest of this book. Tap Brightness.
Unlock the rest of this book. Slide the brightness control to the right to increase brightness and to the left to decrease brightness.
2answers
Tab 3 screen keeps dimming even when im playing on it
seems like you may have the auto brightness turned on. switch it off and set the brighness to your needs, but be careful, the brighter you have it the more battery you are using
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
