20 Most Recent Samsung Galaxy Tab 2 7.0 Questions & Answers
Emails not downloading into inbox, but can send them out.
How to set up and use email on an Android tablet - PC Advisor
www.pcadvisor.co.uk/.../how-to-set-up-and-use-email-on-an-android-tab...
Apr 18, 2011 - Setting up an email account on your Android tablet is not a tricky task, and on our Samsung Galaxy Tab it is extremely straightforward. But you ...
New emails not showing up in Gmail app - Android - Stack ...
android.stackexchange.com/.../new-emails-not-showing-up-in-gmail-app
Aug 2, 2013 - I have 2 different Android devices: a Samsung Galaxy Reverb ... I have to manually change from Priority Inbox to Normal Inbox (or vice versa) in order for the new emails to show up in my list. ... Why does the new Gmail address not show on the Samsung tab 2 version 7.0? ... Turn PS3 Slim into Linux server.
How to Set Up E-mail on the Samsung Galaxy Tab - For ...
1/9/2020 4:58:05 AM • Samsung Galaxy... • Answered on Jan 09, 2020
3answers
What to do if my galaxy wont charge
At this level of charge their is not enough to start the boot process , if it doesn't charge at all their may be a fault with the Battery cell , however i had a similar issue, just leave it for a while, if their is still no indication that its charging or it wont turn on their could also be a problem with the Start Button
1/12/2019 11:34:01 AM • Samsung Galaxy... • Answered on Jan 12, 2019
I tried to unroot my samsung galaxy tab 2 7.0 gt-p3100 and when i reboot the samsung logo won't disappear
Sound like a corrupt load. Try to re-flash or upload a current version The Galaxy is a current model and may be under warranty
12/19/2018 4:41:39 AM • Samsung Galaxy... • Answered on Dec 19, 2018
tip
How to force Samsung Galaxy Tab to shutdown
1.There is no "force shutdown" as far as I know, but you can force a reboot by holding down the power button for about 15 seconds. 2.No force shutdown for galaxy tab, but you can use this trick.
  1. Plug the charger into your galaxy tab.
  2. Hold down power button for 10 seconds, and wait to reboot.
  3. After that, the screen will be change with charging battery.
  4. Plug off your tab, and it will be shutdown.
  5. For Tab S and Tab A Should work with 8.4 or 10.5 6.Hold the Power button, Volume Down button, and Menu key for 10 seconds. You will enter download mode, simply press the volume down button to restart tablet. After reboot, you tablet should perform as normal
My Samsung Galaxy Tab 2 7.0 While reading, I turn to the next page and it shows a blank screen. then 12 to 20 seconds later the next page appears. Then repeats. rebooting many times does not help.
I think you have a corrupted program, maybe a virus. I would do a factory reset to the original programs out of the box
10/31/2016 1:12:49 AM • Samsung Galaxy... • Answered on Oct 31, 2016
Can I update firmware on my galaxy sll 7.0
9/7/2016 2:37:01 PM • Samsung Galaxy... • Answered on Sep 07, 2016
WHAT DOES ERROR RPC:S-7:AEC-0 GM55-W217-JLAUK MEAN
found this for you: https://productforums.google.com/forum/#!topic/play/xPUdySfE3IY
8/16/2016 10:13:53 AM • Samsung Galaxy... • Answered on Aug 16, 2016
4answers
My tablet won't charge
tablet won't charge
7/1/2016 12:22:50 PM • Samsung Galaxy... • Answered on Jul 01, 2016
How do i fix a battery on a samsung tablet
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
5/29/2016 2:25:04 AM • Samsung Galaxy... • Answered on May 29, 2016
Wont power on with plug in
Could be a bad cable, bad power supply or bad the micro usb port? Just a thought.
4/18/2016 10:45:34 PM • Samsung Galaxy... • Answered on Apr 18, 2016
0answers
When I go to text portion using kindle books, the page dims even if the brightness setting is at max
The option to keep the display bright is not found under settings in the Android app, but under the font settings. If you tap the centre of your screen whilst reading your book the icons will appear at the top of your screen. Click the font size icon, and a drop down list of settings will appear. The one at the bottom deals with brightness.
3/14/2016 1:50:29 AM • Samsung Galaxy... • Answered on Mar 14, 2016
Talk back mode cant enter password
Some talk back modes will not allow passwords. It is a security thing. I'm not sure about yours, but that is probably the issue.
2/15/2016 11:32:15 PM • Samsung Galaxy... • Answered on Feb 15, 2016
How do i stop getting text messages from my tablet to my phone
Maybe you should stop sending them from your tablet to your phone. Do you have some text forwarding feature activated?
12/31/2015 12:27:47 PM • Samsung Galaxy... • Answered on Dec 31, 2015
Somehow I change the log in and how to access applications.
Browse the setup parameters, you should find the answer there (or in the manual...).
12/22/2015 2:30:53 AM • Samsung Galaxy... • Answered on Dec 22, 2015
Username shows my last name, how do I block it?
edit your profile to change or call cust service for samsung: 1 (800) 726-7864
12/5/2015 8:31:21 PM • Samsung Galaxy... • Answered on Dec 05, 2015
Samsung Galaxy Tab 2 7.0 Logo
Popular Tags
338 questions posted
Top Samsung Tablets & eReaders Experts
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Tablets & eReaders
Most Popular Question
tablet charge
  • Tablets & eReaders
