-Have you try to plug it to different outlet to see possibly the outlet has no power. Or try different circuit to plug into the one the microwave plug in to see it work or not. If no work then there is not power at that outlet. The breaker is pop.
But if it works then you possibly need new microwave.
If it worked after unplugging and reinserting, it is possible that there is a wiring problem with the plug and wiggling the wires "re-made" a connection. Try plugging in to another outlet to eliminate a dodgy outlet problem.
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement...
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement.. Hope it helps......
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
No power at all? ... gotta ask, assuming it is a counter top model...if you plug something else into the outlet does it work? That way 'we' know there is power getting to the unit. If something else works in the outlet, (assumng a 2 outlet receptical in the wall) plug the microwave into the same outlet as the other item that worked. If still no power, you probably blew the internal fuse in the microwave.
That said, they are there for a reason, chances are there is another problem in the unit that needs to be fixed. An appliance repair man reently told me they are only expected to live 5 or so years anymore... pitiful....
