Question about Hotpoint RVM1625 Microwave Oven
Hotpoint rvm1625sj01 no power - Hotpoint RVM1625 Microwave Oven
Anonymous
    Genius:
  • 1,456 Answers
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Posted on Oct 04, 2011
My hotpoint oven lost all power while cooking
Might be a fuse inside, or the unit may have died. Contact the manufacturer and keep the unit unplugged.
3helpful
We have a Hotpoint RVM1435WJ01 above the range microwave. We lost our electricity one day due to an outside electric wire splitting - when the electric company fixed the wire, the power came back to...
A mains surge may have taken out the fuse. To find the fuse, remove it from the mains, remove the outer cover and follow where the power cable enters the case. There will be a PCBoard with a fuse on it.
Always replace the fuse with one of exactly the same type and value!
What does the red light mean on the hotpoint undercounter freezer r134a?
It just means that it is "on" it has power and is working..that's it...
heatman101
No problem just need to know how many watts is micro model rvm1625sj01
open the door and on the inside it will tell you what wattage it is
Microwave is totally dead but has power to it.
the kliestron is most likely bad or the stertup solenoid is stuck. also could be the control module needs replaced...
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Does the hotpoint microwave model # RVM1535DM1WW
Yes most of them do, take the outer casing off, should be located either were the power supply is or the control module is,
1helpful
Hood light and vent do not operate - everything else works fine
Looked at the schematics and found that one of the wires going from Smartboard to power had been smashed. Spliced this wire and it works great...
Microwave power level
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If you don't have your owner's manual, you can download it free from GE/Hotpoint.
Please reply back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Hotpoint RVM1625 Microwave Oven Logo
Top Hotpoint Microwave Ovens Experts
Gerry Harvey
Gerry Harvey
Ekse
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
