Question about Magic Chef MCM660A Microwave Oven
SERIAL # 20101639 RELEASED 2002 THIS MAGIC CHEF IS USED IN AN RV FUSE BLEW RESET MAIN FUSE MICROWAVE DID NOT COME ON PULLED OUT CHECKED POWER OUTLET AND POWER IS WORKING TO OUTLET CHECKED ON ANOTHER WORKING OUTLET STILL DOES WORK. IS THERE A FUSE IN THE MICROWAVE THAT NEEDS TO BE REPLACED AND IF SO WHERE IS IT LOCATED?
Posted by saltyjr54 on
zappal
    Sergeant:
  • 256 Answers
A bad fuse will not cause this problem.
Posted on Dec 01, 2017
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
Anonymous
SOURCE: magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Posted on Sep 17, 2008
Anonymous
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Posted on Mar 02, 2009
Anonymous
  • 4 Answers
SOURCE: 1992 magic chef (panasonic) microwave. Model
Try this site, it has the best advice on almost ANY microwave problem you can have, I know I read something almost identical to your prob. here:
http://www.repairfaq.org/sam/micfaq.htm.
Posted on Apr 03, 2009
My magic chef microwave died. I replaced fuse, and electrical works but won't cook. Why?
Most likely if the fuse blew the part that creates the microwave energy is defective, it is called the "Magnetron" Just replace the oven is my suggestion.
Nov 11, 2016 | Magic Chef Microwave Ovens
Reset magic chef micorwave breaker
If it doesn't come back on its own, it probably blew its internal fuse. If it blew while the unit was in operation, then I would suggest replacing the fuse holder as well. If it blew when you opened the door, then you may have a bad or mis-adjusted door switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 06, 2016 | Magic Chef Microwave Ovens
I have a Magic Chef microwave over the range (Model: MCO160ub). It is about 2 1/2yrs old and recently it just shut down, the keypad does not operate.and nothing will come on. Previously, it had shut down...
If you could get it to reset by unplugging it I would suspect a problem with the main timer board. A blown fuse or bad connection wont reset by unplugging it. You would need to find a parts dealer who carris Magic Chef parts and give them your model number and ask for price and availability on the main PCB the printed circuit board
( timer board)
Oct 03, 2017 | Magic Chef MCO160UB Microwave Oven
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
No power to oven; checked power to outlet and I do have power; looked for reset button but did not find one
If it is completely dead, check the main fuse, which is likely a AGC ceramic type. If dead, you can buy from Electronix: http://www.electronix.com/ and click microwave in the left column. Good luck with it.
Apr 19, 2011 | Magic Chef MCD1311ST Microwave Oven
No power at all to magic chef microwave. Checked the outlets working
check the fuse.. the location should be specified in the manual.
Apr 14, 2011 | Magic Chef Microwave Ovens
Nothing works i checked the outlet it has power
The main fuse in the microwave oven has blown, usually caused by a defective door switch.
Mar 05, 2011 | Magic Chef MCO160UB Microwave Oven
The power blew while it was on with the dryer
check the hv capacitor for a short and fuse, if thats not the problem call electrician, sounds like a bad breaker
Feb 04, 2010 | Magic Chef CMV1000B Microwave Oven
I was making popcorn and the microwave just died
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jun 07, 2009 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCM660A Microwave Oven Logo
91 people viewed this question
Top Magic Chef Microwave Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
