New problem :door seems to kind of bounce like it does not want to stay open. I found black rubber piece on floor beneath door ? I assume this is something to do with the problem, but not sure what to call it and if it is vital to replace this rubber piece. ? whirlpool dishwasher GU2458xtp53
SOURCE: black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
are there soap suds coming out of the door?
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
SOURCE: I have Whirlpool ADP 962
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
q4w5ifgf
SOURCE: My dishwasher door drops down
replace both door balance cord assemblies on both lower sides of the door where they hinge onto the tub assembly as they are counterweights for the door
