1. Turn off printer 2. Hold down Resume
button and press Power button. 3. Keep holding down Power button and let
Resume button go. 4. Press Resume button 2 times then let BOTH buttons
go. 5. Green lights will flash and then stop blinking. 6. When green
lights are solid, press the Resume button 4 times. 7. Press the Power
button and the printer should turn off, if not, press the Power button
once more. 8. Your printer should respond as normal.For printer
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the power button.) 2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then release the Resume button and Power button. 3) The green indicator flashes during initialization. When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message. (The indicator toggles between orange and green each time the Resume button is pressed.) 4) Next, press the Power button, and the green indicator will light, and the function will be executed. 5) Turn off the printer then back on and error should clear.
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER 2. Release RESUME 3. Press RESUME twice, then release POWER 4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute: presses - light color - function
Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal
1. Turn off printer
8. Your printer should respond as normal..
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
1. Turn off power. 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let the Resume button go. 4. Press Resume button 2 times then let both buttons go. 5. Green light will flash then stop blinking. 6. When Green light is solid, press Resume button 4 times. 7. Press the power button and the printer should turn off. If not, press the Power button 1 more time. 8. Done.
Canon IP 2000 / reset
