I have a Samsung ypk3jqb/xaa. I can connect it to the computer and charge it but in the Samsung media player provided I can't see my device and am unable to load music onto it. I looked at a previous post that told me to update firmware but all those updates were for the XP OS and i have Windows 7 OS. Is there a way I can fix this?
SOURCE: unable to find usb device in media studio
Does your device show up as a separate device in windows explorer? If so you may drag and drop files directly onto it.
Alternatively you can download alternative free media players like winamp and rhapsody which do the same job as media player.
If your device does not show up in windows explorer then you may have a usb problem on your Samsung media player. This is most likely to be a hardware fault which I don't know a free/cheap solution to.
SOURCE: Creative Zen Touch firmware problem
Before preceding, goto control panel, add/remove programs (vista equivalent) select windows media player and uninstall note the response it gives you. If it is going to allow you to uninstall OR downgrade windows media player to version 9 then keep going. If not, then find another computer that you've never used the player on try upgrading firmware there, make SURE it's got windows media player 9 by downgrading it in add/remove programs.
Now for the fun stuff:
Sounds like the same problem I've resolved several times in the past on here.
1. Plug in the device.
2. Goto device manager in control panel and remove the device drivers.
3. Reboot if it asks you to, make sure to unplug the device.
4. Goto device manager again, remove the USB hubs.
5. Don't reboot.
6. Goto control panel, add remove software or equivalent for windows vista ultimate.
7. Select creative labs, and uninstall any and every zen related software.
8. Don't reboot.
9. Goto my computer, find the creative directory located on your main hard drive at \program files\creative. Deleted it completely.
10. Select windows media player select uninstall, or downgrade accordingly.
11. Make sure your zen touch is not plugged in and reboot your system.
12. After system loads, plug in the device and run the firmware software again.
And if you wish, reinstall windows media player 10 and the creative software (which you don't need at all with vista) all the other drivers should reinstall themselves.
BTW it's a hell of alot easier to just use another CPU if you have access to one, I've done it both ways and it saves alot of time.
SOURCE: My windows Xp will not find my samsung YH-925
Helpful website:
http://www.samsung.com/download
SOURCE: Doesn't recogjze device
I found that pressing record+menu for a few seconds, it restarts but I don´t know if files are deleted
SOURCE: cant sync music from media player
same thing happens with Nero when you want to burn a movie that is copy written try with an original cd and see what happens
