20 Most Recent
Samsung YP-T8 Digital Media Player Questions & Answers
Help i have a Samsung YP-T9 and it froze
I had a problem with the Mp3, He was hangup while charging the battery from the USB, I disconnected the USB but It still continuated with the screen charging even if this was disconnected, and I couldn`t hear nothing, so I decided to look in the faq of Samsung, It is Ussless like most of the official pages, how to plug, how to listem the music, but nothing nothing information about how to manage my problem,. So I decided to look in google, and the solutioin was here, press the rec button and the menu button at same time, and magicaly the device was unbloqued. Thanks a lot swamped69 for the solution
I have this samsung mp3
It could be a problem with the cable.
Are you using the same cable you have all along?
One of my players works perfectly well on one cable, bit not on another, although that cable works perfectly on another player.
Also, the cable may be faulty, and not making a data connection, though still charging.
Try a new cable.
My PC doesn't recognize my MP3 player
You have to have a micro SD/T-Flash in the device before it will reconize it. After I installed the micro SD in mine it showed up as the kingston SD in the remove devices drive on the PC.
Battery life cut down to 7 hours
The thing is, you recharge it too much. Because when you recharge it even though it still has battery power left, it tries to recharge it as much as if the battery was depleted. So, your battery overheats, therefore allowing you 7 hours instead of 20. And yes, it is possible to switch the battery.
My samsung yp-t8 is frozen onto 1 pic
Have you tried reset button on bottom of your player, open the small clip where you recharge and you will see the small hole there. Also be certain your hold button is off.Good luck. Pedro2
Micro SD memory card not recognized by computer
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Its basically the same
You have to change the mode of the device (Settings) so that a Windows PC recognizes it.
