Samsung SyncMaster 753S 17" CRT Monitor Logo
Anonymous Posted on Jun 18, 2010
My Monitor suddenly changed and shows vertical position,even mouse arrow is pointed to west, instead of the normal north positioning
Anonymous
Level 3:
Brigadier General:
  • Master 7,191 Answers
  • Posted on Jun 18, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
7191
Questions
Helped
1334951
Points
22939
To restore the monitor or the screen to the original upright position, kindly press these three keys together:
ALT CTRL UP arrow key.(See attached image)
Hope this solves your problem. Thanks for using FixYa.
Testimonial: "My problem is SOLVED, I am very happy and pray for continued progress/innovation skils.With grateful thanks and prsonal regards, GJ Bulsara, LLM,CAIIB,ACS.Formet Chief Legal Adiviser of Leading Financial Institution. I was first to use a PC, that was as big as Refrigerator and Floppy of A4 size Paper.Prsent Age 80 years."
My Acer monitor has 3 inches missing on the left side and 3 inches black on the right
There should be buttons somewhere on your monitor...one named 'Menu' there you should click on an option to change the positioning or horizontal/vertical then follow the instructions...usually the arrow keys...to move the frame to where you need it...hope I helped!
When compass is used the second hand points west instead of north
Are you wearing a ring on your finger that may be magnetic?
That could throw a compass off.
I just bought the Casio SGW500H-2B Mens Twin Sensor 100M Digital Sports Watch Compass Thermometer. My problem is the digital readout in compass mode reads fine but the needle/ second hand points to east...
To fix this, hold down the A button for 4 seconds. this allows you to recalibrate the home position of the second hand. My secondo hand was posting exactly 90 degrees west in compass mode, and this home position recalibration fixed it 100 percent.
2helpful
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 • Watches
Just got my husband a casio pro trek sgw100-1 - we calibrated the compass but east and west are switched - north and south are fine - any ideas? thx
As a pure shot in the dark, are you sure that you calibrated it so that it was pointing to the north when it should be and not to south?
If it was pointing south instead of north, then East and West would be reversed.
Sounds a bit daft but better than the directions of east and west changing?
Check your calibration perhaps?
88 honda prelude double over head cam timing marks
there is a arrow on each cam lets call them north, you will also see marks at east and west to level cams, east and west need to be parallel were the head mets the valve cover while north points up done. Also there is a mark on the flywheel on the crank that needs to point north as well If you have the plastic cover on the lower you will see a plactic to line it up to.
Monitor showing imagens in horizontal position
Toshiba has a screen rotate utility. Try hitting Ctrl + Alt + Up Arrow on the keyboard.
Ctrl + Alt + Left Arrow or Right Arrow may work also.
Garmin Hand held GPS Operation
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It’s hard to cover all the details in a forum like this but I’ll give you a quick primer. I can send you a powerpoint presentation that explains it in a little more detail. To really learn how to read latitude and longitude you should pick up a copy of “Chapman’s Piloting and Seamanship.”
The earth is divided into parallels of latitude and meridians of longitude, also known as lines of position.
Latitude is measured north and south of the equator, with the equator represented as 0 degrees, and the poles being represented as 90 degrees North or South. Latitude lines are paralel to the equator. For example, if I was at the equator I would be at 0 degrees. If I traveled exactly 60 nautical miles to the north, I would be at 1 degree North, and if I traveled another 60 miles I would be at 2 degrees north. Your GPS display will preface the Latitude measurement with an “N” for positions North of the equator and an “S” for positions south of the equator.
Longitude measures your position east or west from the Prime Meridian, which is a line represented as 0 degrees that bisects the earth from north to south and passes through Greenwich England. Halfway around the earth at the International Dateline Longitude is 180 degrees. Measuring Longitude is a little more complicated because the lines are not parallel and requires an accurate clock (your GPS) to compare time at your location relative to the time in Greenwich England. Your GPS display will preface the Longitude measurement with a “W” for positions west of Greenwich and an “E” for positions east of Greenwich.
To make more accurate measurements each degree is divided into 60 minutes. Because the lines are parallel, 1 minute of latitude is equal to 1 nautical mile. Each minute can be further divided into 60 seconds. Each second is roughly equivalent to a distance of 100’ Instead of seconds, the default setting on your Garmin breaks the minute down into tenths, hundredths, and thousandths for meven more precise measurements. Because they are not parallel, lines of Longitude are measured the same way, but the distances vary depending on how far north or south of the equator.
To find out where you are with a GPS, you need a map that shows lines of latitude and longitude on it. The lines will be labeled on the map or along the borders of the map. Most nautical charts show the latitude measurements along the right the left border of the map. Longitude measuremnts will be shown along the top and bottom edges.
2answers
The screen is cutting peoples heads off.
Called aspect ratio or ? depends on Mfr. brand................
When I go into my customers home unfamiliar with their equipment and no owners manual available, I go thru each menu
selection and check each button on the original remote.......T.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
