I have a Maytag Epic washing machine. It would not drain, so i removed the kickplate, drained it all over the floor, removed the stuff that was in the filter, put everything back, and it still won't work. I have a few ideas, but am looking for advice: 1. is there a "reset" switch that I needed to push after clearing the drain? 2. Is there an easy way to drain the thing, in case I have to go back in there and see if i missed something? 3. the drain pump is warm. is that normal?
There is no reset switch on the pump, or program options. If you have cleaned out the drain pumo and it still does not work, you may have a bad pump.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
For future reference: to avoid a messy clean up when cleaning out the drain pump, you can use a wet/dry shop vac to pull a vacuum on the drain line at the standpipe to drain the wash tub and drain lines.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions do apply.
You may have something lodged in to the right side of the filter housing that is still blocking the pump. If the pump is warm, that is an indicator that it is at least trying to run (power is going to it).
I usually pull out the front pump mounting screw to pull the pump forward before removing the trap assembly so that I can put a cake pan under it. I also grasp the large hose in the back of the pump that comes from the tub so that I can "meter out" the water flow to avoid a flood.
There is no re-set that has to be done.
Try removing the entire pump once you get all the water out and you may find something caught in the pump impellar.
Good Luck!
It is a common fault that the drain fails to work in
most machines in a period of time and is the most problematic fault in a
washing machine. In all occasions it is important that your observation is most
important and so is vital to the identification /rectification and solution. If
you have noticed that water has leaked then as the drain hose pump/valve and
fittings are located on the underside of the machine it is important that you
look for possible leaks here. In some cases the drain hose would be clogged at
the drain end to outlet of the house and so there will be back flushing
resulting in overflow to the outside. Also the drain pump/valve can be clogged.
Now remove the drain hose clamps and remove the drain pump/valve, clean the
drain pump/valve, use back flushing to clear off all dirt. Now test using power
to see if this works and can be simulated. When refitting, the hose must be tightened
properly. If the pump/valve does not work even with power then it must be
replaced. If there is intermittent power
to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a
spirit level- so that all water will drain to the outlet port and thereby there
is no residual water remaining.
Replacing the pump on a Bosch machine, please check
this link for tips:
Cleaning a pump:
this link for tips:
