Maytag EPIC MFW9700S Front Load Washer Logo
Posted on May 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Anonymous
Level 3:
Genius:
  • Master 1,400 Answers
  • Posted on May 08, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1400
Questions
Helped
392937
Points
4210
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
9helpful
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
1helpful
When washer starts to wash it beeps and flashes the letters FH.
Hi
Error FH means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 • Dishwashers
14helpful
Washer display flashing error code f-21
The F21 code on the Maytag EPIC is telling you there is a pump problem.
The pump impellers should be checked. There should be four of them.
Sometimes the impeller blades can be broken by coins, etc.
Make sure that the pump is clear of debris, to do this:
Remove the discharge hose, and blow through it.
If after clearing of water, the hose doesn't blow free and clear, you have something stuck in there.
You will need to clear the pump of the item that is stuck inside.
Good Luck,
I hope this helps,
Please rate me,
Thank you
What is a code 2 error for a Maytag Epic wash machine?
F02, usually means drain hose or pump screen is blocked or pump is defective. Using the wrong soap can also cause this problem. Be sure you are using soap marked with the letters "HE" on the front of it.
Helps to have the model number, if possible.
5helpful
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
3answers
Maytag Epic Z frontloader Error Code F20 Help Please!!!
i also have a magtag epic z &f 24 error code is on my washer. i don't know what to do.
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
