Washing Machines Logo
Posted on May 23, 2010
F11 code on kenmore frontload washer HE3t
How do you fix the F11 code on kenmore frontload washer HE3t? What is the cause? Seems as though the washer spin cycle must shake loose some connections. That's when the problem most often occurs.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5090
Points
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
Jeff Hagner
Level 1:
Scholar:
New Friend:
  • Contributor 25 Answers
  • Posted on May 26, 2014
Jeff Hagner
Contributor
Level 1:
Scholar:
New Friend:
Answers
25
Questions
0
Helped
90358
Points
25
The F11 code is caused by either a CCU failure or an MCU failure...here's how to tell:
If your machine starts a cycle and the water fills but the drum NEVER turns, your MCU is bad...it's most cost effective to buy a refurbished one and you can get them on eBay for $99 all day long.
If your machine makes it most of the way through a cycle but throws an F11 code during the rinse or spin, your CCU has the relay solder / vibration problem...and I can fix that for $65.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181300988546
How to run diagnostic on Kenmore elite smartwash quiet pak 9 HE4t washer? Model#110.45087401
Diagnostic mode for Kenmore Elite He3t model 110 42926 ...
iFixit https://www.ifixit.com > Answers > View > Diagnostic...
Apr 8, 2016 - With the washer empty, close the door. · Push "control/on" or "Start" · Select "Drain/Spin" · Select "No Spin" by pressing SPIN SPEED touchpad.
3 answers · 2 votes: I believe this is very similar to the model I have. Here is what I did to run a diagnostic. ...
F11 error code during Diagnostic test? - Kenmore ...
1 answer
Jan 18, 2016
SOLVED: F11 code error on Kenmore HE3 - iFixit
Mar 3, 2011
SOLVED: f h error code - Kenmore Elite HE3 ...
Feb 21, 2012
It seems like the washer has no power - Kenmore Elite ...
Nov 2, 2017
More results from www.ifixit.com
Diagnostic Test; Starting The Test Mode; Test Program ...
ManualsLib https://www.manualslib.com > ... > User manual
Close the door. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button five (5) times. Push Prewash Option button four (4)times within ...
3answers
Hi. Whirlpool washer (Duet front load) GETS F11 error code. Any ideas as to the cause and repair?
Pull off bottom panel, there should be a schematic and trouble shooting guide to help you through any questions about you fault code.
3answers
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
2answers
Getting F11 code r8ght after starting,then flashes and stops
usually if this is a kenmore frontloader f11 is a communication error between the door lock and the ccu board. usually you'll hear a clicking sound before it fails. If so you need a central electric board. It is located directly under the top lid in the back. you can't miss it it's the only thing that has a lot of wires going to it.
What causes the HE3t washer to stop in spin and rinse cycle?
Sometimes the unplugging helps, or hitting "Cancel" several times.  Guaranteed to work though is to remove top, reach down the top to the door lock.  (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door.  This can also be accomplished by removing lower front panel and reaching up to do the same.   BTW, while in the top, make sure all the electrical connections are tight.  I found some loose before, probably from the spinning action.
2answers
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Sears kenmore elite he4t
Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
Error F11
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
Alexander
vince
