Bizhub c 650 not printing through network installed pcl drivers and tried other drivers , not working but if i install c450 it is printing , but colour is not exact in computer
To get to the network settings: Press the Utility/Counter key, select Administrator Settings, enter 12345678 as the password, then select network settings. You will find all the settings for networking the machine there. The print drivers can be downloaded from Konica's web site: kmbs.konicaminolta.us
User manuals can be found there as well.
Well if the other computers print ok to the Bizhub its not the machine, copier does not pick and chose which computer will not work. Try this web site for the most up to date print driver
print out a config page from the fiery. Find the IP address and put that in your web browser. Click on WebTools and the download tab and download the drivers. Install the PCL or PS driver
Did you just install a NIC (aka ethernet port) in your copier?
To print Network Multi PDL Printer Kit C1 needs to be installed. This contains the NIC and the N Boot-Rom. The copier then needs to be upgraded with networked firmware using SST.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Check the number for BOOT-ROM. This should have a N at the end. If not you need to replace the C BOOT-ROM with a N BOOT-ROM.
Also under Copier > Display > Version check the number for PS/PCL. If this is blank then you don't have printer drivers installed on the copier. You will need to get a technician to come out and upgrade the firmware on the machine.
