20 Most Recent Konica Minolta BizHub C252 Questions & Answers
OZONE FAN motor is bad or the filter is totally clogged. remove the filter normal replaced when the black image unit is replaced part of the package or the Black Toner box has one
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Feb 25, 2018
I presume that you want to know what this code means rather than just telling us that you have it!! Search online for "error code c2555 Konica Minolta". Try the fourth hit and onwards.
Konica Minolta... | Answered on Nov 19, 2017
sounds like the sleep timer is activating before the boot is finished try touching the screen and then switch the timer up or if it networked go to the machine web page and turn the timers up from there then try again
Konica Minolta... | Answered on Jul 15, 2017
change Your Toner Cartridge (Compatible then check developer drum Bizhub c252 Parts Manual http://ladinek.com/files/bizhub_C250_Field_Service.pdf
Konica Minolta... | Answered on May 19, 2016
recommend you get a tech out to look at it.
Konica Minolta... | Answered on Jan 24, 2016
why printing with C360 drivers???????????????? try this site and get the correct ones
Self Help Product Support Konica Minolta Business Solutions Inc
there are two filters which one
Konica Minolta... | Answered on Jan 14, 2016
Hard disk failure (the copier Hard drive crashed) Sorry recommended calling a tech to check out
Konica Minolta... | Answered on Jan 13, 2016
MINE YOU THAT IF THIS PROCEDURE DOES NOT WORK DO NOT RESET GAIN YOU ARE DEALING WITH THE FUSER IT CAN CATCH ON FIRE THAT WILL RUIN A PERFECTLY GOOD DAY!!!!!!!! have tech come out replace the fuser
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Konica Minolta... | Answered on Jan 10, 2016
then you will have to set up the ip address and subnet
Konica Minolta... | Answered on Dec 30, 2015
Black image unit (Electronic Chip). Is This unit a 3rd Party? If so replace with a OEM. Always use OEM!!!!.
Konica Minolta... | Answered on Dec 28, 2015
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Konica Minolta... | Answered on Dec 27, 2015
Do you have access to scan to that location input you PIN and password properly.
Konica Minolta... | Answered on Dec 26, 2015
Your Display panel is out. You mite also have a major board problem, recommended that you get a Konica Minolta Tech to look at it. The panel do go out. the panel wear out after a while
Konica Minolta... | Answered on Oct 31, 2015
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Konica Minolta... | Answered on Oct 30, 2015
Transfer Belt Separation
• The 1st Image Transfer Pressure/Retraction Position Sensor doesn't turn ON (Retracting) even after the lapse of a given period of time after the 1st Image Transfer Pressure/Retraction Clutch has turned ON during the Transfer Belt is retracting. • The 1st Image Transfer Pressure/Retraction Position Sensor doesn't turn OFF (Pressuring) even after the lapse of a given period of time after the 1st Image Transfer Pressure/Retraction Clutch has turned ON during the Transfer Belt is pressuring.
Konica Minolta... | Answered on Sep 23, 2015
It going to require a technician because that code series deals with NVRAM which can only be upgraded or replaced by konicaminolta technician who have access to secure server for firmware upload procedures
Konica Minolta... | Answered on May 25, 2015
Replace the Magenta image unit.
Konica Minolta... | Answered on May 13, 2015
Konica Minolta BizHub C252 Logo
31 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
big line magenta page
  • Office Equipment & Supplies
