Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dyson dc 17 vacuum. brush not moving
I cleaned out the brush and put it back together. Now when I am going over carpet the vacuum makes and awful grinding noise. Suggestions?
Anonymous
Level 2:
Sniper:
  • Expert 53 Answers
  • Posted on May 31, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
53
Questions
0
Helped
31286
Points
132
The cog belt is probably not aligned with the motor gear. Watch this video and follow its instructions closely.
2answers
My power head turns real hard or doesnt work..the belt is on but turning it by hand its real tight...everything has been cleaned
Hi Eric,
I would recommend having a look at this video which should hopefully help.
If you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
All the best,
Allan
How can I get the brush on my new Dyson vacuum DC-46 to turn?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 01, 2014 • Vacuums
Squealing when Brushes are moving
they have bearings at the ends of the brushbar it will be them that need changing
2answers
My Dyson DC 14 is making the horrible "ratcheting"sound only when the brush is engaged on the carpet setting. I have cleaned the brush, so there are no obstructions, the canister is empty and...
Something is causing the brush to slow down, either it is full of hair or debris or the brush itself is wearing out and may need changed. The noise you are hearing is the motor protector keeping it from burning up becuse there is some type of drag on the brush. If there is no issues with the brush then I would suspect the clutch assembly is worn and needs replaced. Here is a diagram for you to look at and go from there.
http://www.espares.co.uk/diagram/dyson/dc14-vroom/p/1086/716/0/474352
When in carpet mode, brushes seem to be hitting something. Brushes cleaned - how to stop making the awful noise
LOL do you mean when you move the vacuum forward (say into a baseboard)? it makes the loud shocking noise.. i hate that too.. but that's the crazy Warning sound indicating something is stuck (like you sucked up an area rug) or you have run into something and it set off a sensor.
Carpet cleaning brush noise. When put in carpet cleaning mode, a loud noise comes from the brush bar area. We see no visible obstructions and have cleared threads and hair.
It's likely that one of the brush roll bearings has worn out. This is not uncommon. I think you'll find that you have to replace both the brush roll and the sole plate at the same time. Dyson sell them together as a kit.
2answers
Dyson eats my carpet
When using the Dyson or for that matter any other vacuum cleaner that has a motorized roller brush, you need to make sure that you AVOID open carpet edges since the suction end ( which has a roller with the brush) will grab open fiber ends. You should use an attachment or floor tool when cleaning open edges of your rug or carpet. Most vacuum cleaners come with a range of attachments that be used be used appropriately.
162helpful
9answers
DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
