The water loads in, but the machine doesn't turn, and then just clicks.
That clicking sound is most likely from your overheat safety switch located on the motor. This trips when there is too much bind or friction from the drum causing your motor to overheat I would check the drum bearing first by trying to turn the drum on your machine from the door area.
If it turns, it may be ok, but just to be sure, take the rear cover from your machine and remove the belt on the large pulley, then try starting the machine again. If you hear a hum and the clicking goes away you most likely have a bad drum bearing.
